Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
For the life of me.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: For the life of me. (Read 987 times)
jlogan02
Bull Frog
For the life of me.
on:
November 16, 2020, 05:57:11 PM »
This routine does mostly what I want. I need to select all Mtext with color overridden to red "without user input".
For whatever reason, this baffles!!!
Code - Auto/Visual Lisp:
[Select]
defun
c:MTColor
e o txt
if
and
setq
e
car
entsel
\n
Pick mtext: "
"MTEXT"
cdr
assoc
0
entget
e
setq
o
vlax
ename
vla-object
e
progn
setq
txt
vla-get-textstring
o
while
vl-string-search
C1;"
txt
setq
txt
vl
string
subst
C256;"
C1;"
txt
vla-put-textstring
o txt
princ
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
jlogan02
Bull Frog
Re: For the life of me.
Reply #1 on:
November 16, 2020, 06:05:04 PM »
Never mind...
this seems to work.
[Select]
defun
c:nameit
int o txt
if
setq
sel
ssget
"_X"
0
"MTEXT"
;;Mtext
repeat
setq
int
sslength
sel
setq
obj
vlax
ename
vla-object
ssname
sel
setq
int
1-
int
progn
setq
txt
vla-get-textstring
obj
while
vl-string-search
C1;"
txt
setq
txt
vl
string
subst
C256;"
C1;"
txt
vla-put-textstring
obj txt
princ
Logged
J. Logan
ACAD 2018
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
For the life of me.
