Author Topic: Placing Text with bad results  (Read 1573 times)
GDF
« on: September 06, 2016, 09:11:10 AM »
When zoomed in close to the line for placing the text, the text is placed correctly. If zoomed out the text is not placed as per the routine.
Why does zoomed in make a difference, and how can I fix it.
I always want (setq pnt2 (polar pnt1 (+ ang1 2) 3)) to work.
(defun RTIT (/ rline firstendpnt secondendpnt pnt1 pnt2 ang1 txt agl ang angd xx)
  (setvar "CMDECHO" 0)
  (setvar "OSMODE" 512)
  (setq rline     (entsel "\n* Pick Roof Line: ")
        firstendpnt  (trans (cdr (assoc 10 (entget (car rline)))) 0 1)
        secondendpnt (trans (cdr (assoc 11 (entget (car rline)))) 0 1)
        ang1         (angle firstendpnt secondendpnt)
        pnt1         (arch:mid firstendpnt secondendpnt)
  (if (and (<= ang1 4.71239)(> ang1 1.5708))(setq ang1 (angle secondendpnt firstendpnt)))
  (command "_.text" "j" "bc" pnt2 "" 0 (strcase ITEM))
  (setq AG (angle firstendpnt secondendpnt))
           (setq AGL (car (list (cons 50 ang1))))
           (setq N 0)
           (setq TXT (ssget "L"))
           (repeat (sslength TXT)
             (setq
               Elist (subst AGL (assoc 50 (entget (ssname TXT N))) (entget (ssname TXT N))))
             (entmod Elist)
             (entupd (ssname TXT N))
             (setq N (+ N 1)))
  (princ))
(defun C:RT ()
 ; (ARCH:F_S-VAR)
 ; (cond ((= ARCH#CLAY "Off") (ARCH:LYR "A-ROOF-NOTE")))
 ; (ARCH:SET-ARIAL)
  (initget 7 "G H R K V E")
  (setq TYP (getkword "\n* Select: [Gable, Hip, Ridge, raKe, Valley, Enter text: ] *"))
  (cond ((= TYP "G") (setq ITEM "GABLE"))
        ((= TYP "H") (setq ITEM "HIP"))
        ((= TYP "R") (setq ITEM "RIDGE"))
        ((= TYP "K") (setq ITEM "RAKE"))
        ((= TYP "V") (setq ITEM "VALLEY"))
        ((= TYP "E") (setq ITEM (getstring 1 "\n* Type in text: ")))
  (while (/= (getvar "cmdactive") 1)(RTIT))
 ; (ARCH:F_R-VAR)
GDF
Re: Placing Text with bad results
« Reply #1 on: September 06, 2016, 09:27:50 AM »
(defun ARCH:MID  (w z)
  (list (/ (+ (car w) (car z)) 2) (/ (+ (cadr w) (cadr z)) 2)))
roy_043
  • BricsCAD 18
« Reply #2 on: September 06, 2016, 09:40:13 AM »
Seems like a *classic* running osnap issue.
Change osmode or use "_non" to override.
EDIT: typo.
« Last Edit: September 06, 2016, 09:59:52 AM by roy_043 »
GDF
« Reply #3 on: September 06, 2016, 09:43:50 AM »
Works perfectly now. Thank you very much!
GDF
« Reply #4 on: September 06, 2016, 10:50:43 AM »
Here is the updated routine with sub functions included:
Command name RT.
If you cannot get the sub functions to work, just comment them out, or remove them in the main routine.
Gary
