When you say "dimension text" are you just going after the dimension override?
Or are you looking to combine the override with the dimension?
Just the override. I'm trying to steer away from having to modify a whole drawing, entity by entity. I'll explain in detail (keep in mind I'm typing this in between waiting for Mickeystation/Projectwise drawings to open/close as I have a rush job at the moment and will be working all W.E.).
In suspect drawing, all dimensions with fractions use special ASCII Chars. for fractions (R14 and below dwgs) and they are all overrides. This means that in, say a structural drawing there will be about 50 or so dimensions with text that looks like 9'-3%%206". When I explode the dimension and then the text, the text breaks into 2 entities, leaving one 9'-3 and a separate fraction entity. This is causing me extreme grief. If I could globally change all dimension text to DTEXT, my life would get a little easier. Carol Bartz will be getting a letter, and I will be adjusting her scorcard pending the outcome.
Clear as mud?
