Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Layer's block with Design Center
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Layer's block with Design Center (Read 1581 times)
Patrick_35
Guest
on:
February 05, 2014, 05:12:42 AM »
Hi
With the Design Center, it's possible to assign a layer to a block (with property).
Can we get this layer with lisp/vlisp ?
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: Layer's block with Design Center
Reply #1 on:
February 05, 2014, 07:02:02 AM »
I don't recall seeing the capability of setting the layer for blocks from DesignCenter.
Care to remind us how you do that ?
Logged
Patrick_35
Guest
Reply #2 on:
February 05, 2014, 08:08:11 AM »
Sorry, I was wrong.
It's tools palettes I wanted to said.
I stopped the Calva in coffee
Logged
alanjt
Needs a day job
Standby for witty remark...
WWW
Reply #3 on:
February 05, 2014, 08:08:24 AM »
You can set a layer to a block from within Tool Palettes, but I've never seen a way to do it in Design Center.
edit: should have read the warning before hitting submit the 2nd time.
Logged
Dropbox
alanjt
Needs a day job
WWW
Reply #4 on:
February 05, 2014, 09:26:00 AM »
You can read each palette's layer, etc. from the atc file.
Logged
Dropbox
Patrick_35
Guest
Reply #5 on:
February 05, 2014, 09:45:44 AM »
Thank you very much
I found the information in atc file
Regards
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
