Author Topic: how to shuffle a set of list ?  (Read 7194 times)
highflyingbird
  • Later equals never.
Re: how to shuffle a set of list ?
« Reply #15 on: July 25, 2012, 12:48:36 PM »
the length of list is longer,my code runs faster.
On my computer, 20000 items , 10 times test:
HFB:shuffle takes: 1.932 Seconds .
Average performance: 0.1932 Seconds/time.
ShuffleList2 takes: 173.458 Seconds.
Average performance: 17.3458 Seconds/time.
The difference is very huge.
My Big O notation is O(n),maybe the others is O(n^2).
« Last Edit: July 25, 2012, 01:27:15 PM by HighflyingBird »
I am a bilingualist,Chinese and Chinglish.
RAIN CODE
« Reply #16 on: July 26, 2012, 12:03:11 AM »
You guys are really good. I have still a lot to learn when it come to List.
All the lisps here are shorter than mine. No doubts about it.
I was thinking since my game's lisps are written all in module (subroutines)
Next time I post the game here, maybe someone here could re-write some of the module which I think there are
alot of rooms for improvement. If it shorter I am sure it will run faster.
There are alot of suggestions here dunno which to use  ^-^. All looks so good
Thanks again.
highflyingbird
« Reply #17 on: July 26, 2012, 01:29:42 AM »
Just a little bit of changed,to simulate the lotto:
  1. (defun HFB:GetLottery (MaxNumber Count / i lst array temp Index lastIndex Lottery)
  2.   (setq i MaxNumber)
  3.   (repeat MaxNumber
  4.     (setq lst (cons i lst))
  5.     (setq i (1- i))
  6.   )
  7.
  8.   (setq LastIndex (1- MaxNumber))
  9.   (setq Array (vlax-safearray-fill (vlax-make-safearray vlax-vblong (cons 0 LastIndex)) lst))
  10.
  11.   (setq i 0)
  12.   (repeat Count
  13.     (setq Index (LM:RandomRange i LastIndex))
  14.     (setq temp (vlax-safearray-get-element array Index))
  15.     (vlax-safearray-put-element array Index (vlax-safearray-get-element array i))
  16.     (vlax-safearray-put-element array i temp)
  17.     (setq Lottery (cons temp Lottery))
  18.     (setq i (1+ i))
  19.   )
  20.   (reverse Lottery)
  21. )
In China, "double chromosphere":
(cons (LM:randomRange 1 16) (hfb:getlottery 32 6))
(12 17 27 28 32 8 7)
Did you guessed this group numbers? Break your leg! :laugh:
« Last Edit: July 26, 2012, 01:38:54 AM by HighflyingBird »
irneb
« Reply #18 on: July 26, 2012, 02:57:32 AM »
HFB: You're correct! Whenever you use nth on long lists, it's always faster to use an array instead. That's where arrays are better to use than linked-lists (indexing is a simple multiplication instead of an iteration).
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: July 26, 2012, 03:15:36 AM »
to solve the problem, really need a full randomization or enough each time to have a different order?
I see the opportunity to multiply to simplify the solution...
irneb
« Reply #20 on: July 26, 2012, 06:58:55 AM »
Just one thing HFB: Yours would only work if the list contains all the same types. And you'd need to modify the code in order to have a list of different types. Or you could change your function to something like this (hope you don't mind  ;) ):
  1. (defun HFB:shuffleTyp  (lst DataType / count array i lastIndex RandNum tmp)
  2.   (setq count (length lst))
  3.   (setq Array (MakeSafeArray (mapcar 'vlax-make-variant lst) DataType)) ;->maybe other type
  4.   (setq i 0)
  5.   (setq LastIndex (1- count))
  6.   (repeat LastIndex
  7.     (setq RandNum (LM:randomrange i LastIndex))
  8.     (setq tmp (vlax-safearray-get-element array RandNum))
  9.     (vlax-safearray-put-element array RandNum (vlax-safearray-get-element array i))
  10.     (vlax-safearray-put-element array i tmp)
  11.     (setq i (1+ i)))
  12.   (vlax-safearray->list array))
Or to have it work exactly as the list-based versions
  1. (defun HFB:shuffleVar  (lst / count array i lastIndex RandNum tmp)
  3.   (setq Array (MakeSafeArray (mapcar 'vlax-make-variant lst) vlax-vbVariant)) ;->maybe other type
  4.   (setq i 0)
  12.   (mapcar 'vlax-variant-value (vlax-safearray->list array)))
An alternative list-based method ... using 6 Packs, then "dealing" each item from the list randomly into one of each pack, and then stacking the packs into one again
  1. (defun ShuffleList6  (lst / pac0 pac1 pac2 pac3 pac4 pac5 v)
  2.   (foreach item  lst
  3.     (setq v (read (strcat "pac" (itoa (rem (fix (* (Random nil) 6)) 6)))))
  4.     (set v (cons item (eval v))))
  5.   (append pac0 pac1 pac2 pac3 pac4 pac5))
It's not all that bad compared to the array method for long lists (tested on 20000 integers)
Benchmarking ..... done for 8 iterations. Sorted from fastest.
Statement                                Increment  Time(ms) Normalize  Relative
(HFB:SHUFFLE LST)                                8      1998      1998     54.15
(HFB:SHUFFLETYP LST vlax-vbLong)                 8      2029      2029     53.33
(HFB:SHUFFLEVAR LST)                             8      2200      2200     49.18
(SHUFFLELIST6 LST)                               4      1278      2556     42.33
(SHUFFLELIST LST)                                1     13525    108200      1.00
And comparing list of 50 items:
Benchmarking ............ done for 2048 iterations. Sorted from fastest.
(SHUFFLELIST2 LST)                            2048      1263      1263     21.14
(HFB:SHUFFLE LST)                             2048      1436      1436     18.60
(SHUFFLELIST LST)                             2048      1497      1497     17.84
(HFB:SHUFFLETYP LST vlax-vbLong)              2048      1497      1497     17.84
(HFB:SHUFFLEVAR LST)                          2048      1606      1606     16.63
(SHUFFLELIST6 LST)                            2048      1903      1903     14.03
(SHUFFLELIST5 LST)                            1024      1404      2808      9.51
(LM:SHUFFLE LST)                              1024      1436      2872      9.30
(SHUFFLELIST4 LST)                             512      1013      4052      6.59
(SHUFFLELIST3 LST)                             512      1107      4428      6.03
(PH:SHUFFLE1 LST)                              512      1512      6048      4.42
(SHUFFLE LST)                                  128      1669     26704      1.00
Overall, it seems yours is the fastest for a wide range of list lengths. Even the mod to use variants is still faster.
