Code Red => .NET => Topic started by: dbroada on September 21, 2010, 05:46:52 AM
I am migrating some of my VBA code to .Net and thought I had found an easy routine to practice on. I may be wrong! I bring (upto) 3 dxf files into a single drawing and then save the file. To do this I use the following sub
Public Sub DxfImport(myFile As String)
Dim P1(0 To 2) As Double
Dim myScale As Double
Dim myTest
If Right$(myFile, 4) <> ".dxf" Then myFile = myFile & ".dxf"
myTest = Dir$(myFile)
If myTest <> "" Then
P1(0) = 0: P1(1) = 0: P1(2) = 0
myScale = 1
ThisDrawing.Import myFile, P1, myScale
End If
What I can't find is a .Net equivalent of the
line. Is there such a thing and if there is, how do I access it?
(this is the VBA Import, not the AutoCAD import)
object Import(string FileName, object InsertionPoint, double ScaleFactor);
Declaring Type: Autodesk.AutoCAD.Interop.IAcadDocument
thank you, that looks easy. However I am obviously missing something here (i'm new to .Net - not too obvious I hope).
I'm still not sure how to put that in to practice. I have the following but still have errors at the .interop & (Import stages. Have I failed to reference something somewhere?
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.interop
Public Class Hellooo
<CommandMethod("Ducks")> _
Public Sub DucksIn(ByVal myFile As String)
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim p1(0 To 2) As Double
Dim myTest
If Right(myFile, 4) <> ".DXF" Then myFile = myFile & ".DXF"
myTest = Dir(myFile)
p1(0) = 0 : p1(1) = 0 : p1(2) = 0
myScale = 1
acDoc(IMPORT(myFile, p1, myScale))
Else
MsgBox("File doesn't exist")
End If
making the Import line into Autodesk.AutoCAD.Runtime.Interop has got rid of one error message but not the other. :-(
In net a point is usually an actual point (point2d or point3d) not just an array of doubles. You may have to make a point3d here, it isn't clear
thank you, but wouldn't that just throw up an error at the relavent term rather than refusing to acknowledge the existance Import element?
(Off to give it a try at next coffee break)
This will get you a little further
This is not ".Nettyish"
<CommandMethod("Ducks", CommandFlags.Modal + CommandFlags.Session)> _
Public Sub DucksIn()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim pr As PromptResult = ed.GetString(vbCrLf & "Enter File: ")
If pr.Status = PromptStatus.OK Then
Dim myFile As String = pr.StringResult
Dim fNameNoExt = Path.GetFileNameWithoutExtension(myFile)
Dim acDoc As AcadDocument = doc.AcadDocument
Dim p1 As Point3d = Point3d.Origin
Dim myScale As Double = 1
If File.Exists(myFile) Then
myFile = fNameNoExt
ElseIf Not File.Exists(fNameNoExt & ".dxf") Then
MsgBox("File does not exist")
End If
myScale = 1
acDoc.Import(myFile, p1, myScale)
End If
fro2001, it gets me a little closer, but only a little. My system is not recognising the AcadDocument type. If I change that to Document it the throws up an error with the import bit.
Now that several people have helped I guess I should declare my set up just in case I am trying to do something not possible.
I am using AutoCAD 2008 electrical and Microsoft Visual Basic 2010 express.
I have only been formerly trained in Fortran as a programming language (and have dabbled with BASIC, VB & VBC on a self taught basis) so I am struggling to grasp .Net at the moment.
and what do you mean by ".Nettyish"> :?
This works for me.
I'll leave the translation to someone who likes playing with VB
{ Forum Profile->Look And Layout Prerferences -> Current Theme: Mercury}
// CodeHimBelonga kdub@theSwamp 20100922
using System;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
using System.IO;
using System.Windows.Forms;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(Ducks.MyCommands))]
namespace Ducks
public class MyCommands
[CommandMethod("Ducks", (CommandFlags.Modal | CommandFlags.Session))]
public void DucksIn()
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
PromptResult pr = ed.GetString(("\r\n" + "Enter qualified File: "));
if (!(pr.Status == PromptStatus.OK))
return;
string myFile = pr.StringResult;
if (!File.Exists(myFile))
string msg = string.Format("File {0} does not exist", myFile);
MessageBox.Show( msg, "Ooooooops");
return;
AcadDocument comDoc = (Autodesk.AutoCAD.Interop.AcadDocument)doc.AcadDocument;
double myScale = 1;
Point3d p1 = Point3d.Origin;
double[] ptArray = p1.ToArray();
comDoc.Import(myFile, (object)ptArray, myScale);
can I send you several hundred drawings to process :-D
I think it must be my references rather than the code :-o as I still can't get the Interop bit to be accepted....
I reference these for development:
[edit:added] the references shown are for MY configuration (Win7;64bit,ACADM2011;VS2010Pro), yours may differ.
YEAH!!!!!!
all the underlining has disappered. Now to work out if I understand the solutions offered.
I'm sure I will be back. :-)
You can also reference the Interops from the GAC ... something like ;
C:\Windows\assembly\GAC_MSIL\Autodesk.AutoCAD.Interop\18.1.0.0__eed84259d7cbf30b\Autodesk.AutoCAD.Interop.dll
Dave,
If you like, but it sounds as if you're almost there.
and besides, I'm not cheap even if I am nasty :)
That reminds me of the saying 'I may be cheap, but I'm rough'
right, clearly out of my depth here (but thanks for the help so far). At least I know what I want can be done, its just that I can do it. :-(
here is the code I am (attempting to) running. If I uncomment the Dim acDoc As AcadDocument = doc.AcadDocument line I get an error message (hopefully produced below).
To my understanding VB 2010 express doesn't support debugging but by use of MsgBox I know that is the line it is failing on. Before I give up for winter :cry: is there anything obvious that I haven't yet done?
Imports System
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports System.IO
Imports AcadApp = Autodesk.AutoCAD.ApplicationServices.Application
'Dim acDoc As AcadDocument = doc.AcadDocument
myFile = fNameNoExt
End If
myScale = 1
'acDoc.Import(myFile, p1, myScale)
End If
How about this
' CodeHimBelonga kdub@theSwamp 20100922
Imports System
Imports System.IO
Imports System.Windows.Forms
Namespace ducks_vb_
Public Class MyCommands
<CommandMethod("Ducks", (CommandFlags.Modal + CommandFlags.Session))> _
Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim pr As PromptResult = ed.GetString(("" & vbCrLf + "Enter qualified File: "))
If Not (pr.Status = PromptStatus.OK) Then
Return
End If
If Not File.Exists(myFile) Then
Dim msg As String = String.Format("File {0} does not exist", myFile)
MessageBox.Show(msg, "Ooooooops")
Return
End If
Dim comDoc As AcadDocument = CType(doc.AcadDocument, Autodesk.AutoCAD.Interop.AcadDocument)
Dim ptArray() As Double = p1.ToArray
comDoc.Import(myFile, CType(ptArray, Object), myScale)
End Class
End Namespace
I'll be back shortly .. need to go scrub my hands :lol:
I thank you now for getting your hands dirty and hopefully I will be back tomorrow (really MUST do some project work today) thanking you for an excellent routine.
Washed my mouth out too ... vb does that to me :|
You're welcome ... I learnt stuff too.
Note that I had the CommandFlags OR'd ; I've changed them to And'd
ie
& in C# [added] WRONG .. should be | or + ; kdub 20100923
+ in VB <- [added] Can someone confirm this Please ?
ie
& in C#
There is both an & operator and an && operator.
I copied the help file below.
The & operator can function as either a unary or a binary operator.
Remarks
The unary & operator returns the address of its operand (requires unsafe context).
Binary & operators are predefined for the integral types and bool. For integral types, & computes the logical bitwise AND of its operands. For bool operands, & computes the logical AND of its operands; that is, the result is true if and only if both its operands are true.
The & operator evaluates both operators regardless of the first one's value.
The conditional-AND operator ( &&) performs a logical-AND of its bool operands, but only evaluates its second operand if necessary.
oh . . . . you meant the vb didn't you? he he
OK, I've checked by testing.
The AutoCAD .NET Developer's Guide Command Definitions page is wrong. :-o
The example shows the CommandFlags using & in the sample
It SHOULD use | or +
The Values are :
[Flags]
public enum CommandFlags
TempShowDynDimension = -2147483648,
Modal = 0,
Transparent = 1,
UsePickSet = 2,
Redraw = 4,
NoPerspective = 8,
NoMultiple = 16,
NoTileMode = 32,
NoPaperSpace = 64,
NoOem = 256,
Undefined = 512,
InProgress = 1024,
Defun = 2048,
NoNewStack = 65536,
NoInternalLock = 131072,
DocReadLock = 524288,
DocExclusiveLock = 1048576,
Session = 2097152,
Interruptible = 4194304,
NoHistory = 8388608,
NoUndoMarker = 16777216,
NoBlockEditor = 33554432,
NoActionRecording = 67108864,
ActionMacro = 134217728,
NoInferConstraint = 1073741824,
This Piccy Tells the story I think.
I'll advise Kean and see if we can get it fixed.
With vb you can use the logical operator. This is correct :
<CommandMethod("Ducks", (CommandFlags.Modal Or CommandFlags.Session))> _
now you are in areas that I have no understanding of I'll just report that I finally have something working. I have got myself so confused with all the error messages I have received! However, now that I have built to Net3.5 (rather than 4) and made the Interop.dll copy local I am seeing results with a very minimal version of Kerry's solution. I will now try with his full solution!!!
Many thanks for your time.
I will be back so lets hope somebody asks a question I can answer before I have built up too much debt.
I didn't think I would be back so soon. Kerry, thank you, your code (almost) works perfectly. The only bit not quite right is around the "oooops" message box but that is not a show stopper. And may well be irrelevant after the next question....
What changes would need to be made to run that routine with a supplied file name? I build up loop diagrams from 3 DXF files and combine them into 1 file. I currently use a script to do this which looks something like
sdi
1
new
acadiso
vbastmt
DxfImport("P:\Design_Office\E281\LOOPS\Output\July-2010\E281-10-LD001-528_0.dxf")
vbastmt
DxfImport("P:\Design_Office\E281\LOOPS\Output\July-2010\E281-10-LD001-528_1.dxf")
vbastmt
DxfImport("P:\Design_Office\E281\LOOPS\Output\July-2010\E281-10-LD001-528_2.dxf")
saveas
2007
"P:\Design_Office\E281\LOOPS\Output\July-2010\E281-10-LD001-528"
resume
ultimately I want to replace the DxfImport bit with the new .Net routine.
Why you would ever want to combine these 2 flags is beyond me:
Sorry for the CommandFlags.Modal + CommandFlags.Session
I should of not put it in there thanks for catching that
For the "short circuiting" I thought
C# &&
VB ANDALSO
C# ||
VB ORALSO
