Author Topic: coordinate problem sending command  (Read 2580 times)
mohnston
  • CAD Programmer
« on: September 25, 2007, 01:26:28 PM »
This is my first post in the LISP area so be nice.
There is a bug in AutoCAD where when you plot limits you can get unwanted results.
It happens when you change dview. In my case it was when we used the 3DOrbit function and then reset the view using the "PLAN" command.
Anyway I am trying to write a quick fix for when it happens.
For some reason the second point passed using PlotFix causes an error.
(DEFUN C:PlotFix()
(setvar "CMDECHO" 1)
(command "DVIEW" "All" "" "Points" "0,0,0" "0,0,1" "")
I get this result:
[start]
Command: PLOTFIX
DVIEW
Select objects or <use DVIEWBLOCK>: All 1 found
Enter option
[CAmera/TArget/Distance/POints/PAn/Zoom/TWist/CLip/Hide/Off/Undo]: Points
Specify target point <1.0000, 1.0000, 1.0000>: 0,0,0
Specify camera point <1.0000, 1.0000, 2.0000>: 0,0,1
Camera and Target may not be coincident
; error: Function cancelled
[end]
Funny thing is if I enter 0,0,1 and press enter the points are set and all is OK.
I thought of setting system variables for the values but they are read only so I think I'm stuck with using "command".
Any help is appreciated.
<edit: tags added-CAB>
« Last Edit: September 25, 2007, 01:37:24 PM by CAB »
CAD Programming Solutions
Re: coordinate problem sending command
« Reply #1 on: September 25, 2007, 01:29:24 PM »
This seemed to work for me
(command "_.dview" "_all" "" "_points" '(0.0 0.0 0.0) '(0.0 0.0 1.0) "")
« Reply #2 on: September 25, 2007, 01:38:03 PM »
We're always nice.  8-)
mohnston
  • CAD Programmer
« Reply #3 on: September 25, 2007, 01:52:08 PM »
It works for me too. Thanks.
I thought of sending in points instead of strings but couldn't get it to work. Probably got the syntax wrong.
The frustrating part is if you send in "1,1,1" "1,1,2" AutoCAD doesn't complain. But "0,0,0" "0,0,1" breaks it.
Ok, now I've got to get out of the LISP area and back to .NET before I get cooties.
Thanks again for the help.
CADaver
« Reply #4 on: September 25, 2007, 05:46:26 PM »
running osnap??
« Reply #5 on: September 25, 2007, 06:11:19 PM »
Those pesky little devils. :evil:
Test this:
(DEFUN C:PlotFix()
(command "DVIEW" "All" "" "Points" "_non" "0,0,0" "_non" "0,0,1" "")
