Author Topic: how to know if there is a xref  (Read 5047 times)
DEVITG
« on: April 11, 2004, 04:52:43 PM »
There is any variable or other fact that can give if a drawinw had xref to it?
Mi intention is to verify if a drawing had a xref.
hyposmurf
« Reply #1 on: April 11, 2004, 06:23:37 PM »
I suppose you mean after the XREF has been binded?Otherwise the XREF Manager will tell you.
DEVITG
« Reply #2 on: April 11, 2004, 06:53:37 PM »
I just want to know if a drawing has a xref or not , before doing nothing.
hyposmurf
« Reply #3 on: April 11, 2004, 06:58:57 PM »
Well your xref manager will tell you what xrefs you have attached,detached or unloaded.It wont tell you though what xrefs have been bound.
« Reply #4 on: April 11, 2004, 07:02:38 PM »
Try this.....
(defun C:ISXref ( / n name ndx sset strlist xreflist )
  (setq sset (ssget "x" '((0 . "insert"))))
  (setq ndx 0)
  (if sset
    (repeat (sslength sset)
      (setq name (cdr (assoc 2 (entget (ssname sset ndx)))))
      (if (>= (cdr (assoc 70 (tblsearch "block" name))) 4)
        (if (not (member name xreflist))
          (setq xreflist (append (list name) xreflist))
      (setq ndx (1+ ndx))
  (if xreflist
   (setq strlist "\"This drawing contains these XRefs \" & vbCr & \"")
   (setq strlist "\"This drawing contains no XRefs \"")
  (foreach n xreflist
   (setq strlist (strcat strlist n "\" & vbCr & \""))
  (command "vbastmt" (strcat "MsgBox " strlist))
Have fun....
hyposmurf
« Reply #5 on: April 11, 2004, 07:04:30 PM »
Cool that works  :).Did you just come up with that on the spot or have it tucked away?
« Reply #6 on: April 11, 2004, 07:09:07 PM »
On the spot
hyposmurf
« Reply #7 on: April 11, 2004, 07:09:54 PM »
You little whiz! :)
« Reply #8 on: April 11, 2004, 07:10:30 PM »
:oops:
« Reply #9 on: April 11, 2004, 07:15:52 PM »
lol.
Hypo, once you know what each autolisp function does the coding is the pain in the butt part of code development. (Somtimes i hate writing code. ...it takes way to long to type out my thoughts.) kinda like driving. When you were 16 you wanted to drive everywhere and then when you got older you wanted that transporter thingie you saw in the startrek movie cause the drivng part was the crapy part.
lol
DEVITG
vabastmt
« Reply #10 on: April 11, 2004, 07:25:04 PM »
Hi Keith , would you be so kind to explain the following feature??? :oops:
BTW: the ISXREF works great.
« Reply #11 on: April 11, 2004, 07:33:43 PM »
.. or if you just want a count, this will tell you how many are recorded in the database, not how many are displayed
(defun c:test (/ count)
  (setq count 0)
  (vlax-for each (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (if (= (vla-get-isxref each) :vlax-true)
      (setq count (1+ count))
  count
« Reply #12 on: April 11, 2004, 07:33:51 PM »
Well, I wanted to make the user aware of any xrefs located in the drawing....In LISP the alert window ... i.e.
(alert "blah blah blah")
is limited to the amount of information you can "effectively" put into it. So, rather than fight with calling the base acad.dcl file and loading the dialog for it etc.... I simply parsed the entire list of the xrefs in the drawing and added them to a string..that string would be formatted with the name of the xref n a quote " the VBA command for connecting strings & the VBA constant for a carriage return vbCr for the formatting in the message box, followed by another open quote " that would preceed the next xref name stored in the variable n.
Now, there is a command line call that you can use to call VBA commands simply by entering the VBA code directly on the command line. That command is vbastmt which is essentially "VBA Statement"
The bit of code following is the statement string that is passed to the command line.. opening a message box MsgBox and passing the string list of names and carriage returns strlist to the message box command.
and I am glad it works like it should....
hyposmurf
« Reply #13 on: April 12, 2004, 05:48:18 AM »
Quote from: Se7en
lol.
lol
I was just amazed that Keith was only online for a short while and he'd knocked together his own custom code for solution,tested it and posted it.Trully an art in itself,would be smart to be able to do that at work. :)
« Reply #14 on: April 12, 2004, 08:17:01 AM »
lol...
Well, I have done very similar things in the past, so I had a pretty good understanding how it should work...
Actually I changed the code significantly before I even posted it...I could be considered having written 2 versions and posting only the best one...
Here is what I initially put together (psudocode only)
select inserted blocks in drawing
extract block names and put them in a list
step through the block table extracting block names and putting them in a list if they are xrefs.
Step through the xref block list and see if any of them are in the inserted blocks list if they are put it in a new list
Display the new list (referenced xrefed blocks) on the command line
but I elected to make it like this
step through each block
extract block name
find block table reference of block name
if it is an xref put it in a list
format a text string
display text string in message box
It is somewhat smaller and I think easier to understand...
