Author Topic: Anyone know of a block wipeout routine?  (Read 1410 times)
nobody
  • .net stuff
« on: January 31, 2018, 01:36:45 AM »
Anyone know if something exists already that will add wipeouts to simple blocks (symbols, signs, etc)?
Thanks!
BIGAL
  • 40 + years of using Autocad
Re: Anyone know of a block wipeout routine?
« Reply #1 on: January 31, 2018, 03:10:08 AM »
Using the pline option is the simplest but the hard part is if you want some form of shape around your block. There is software out there that will draw a pline around an object, a common description is a boundary of objects but some methods are better than others. I would start with googling "boundary lisp". There is one version of software out there that appears to be good but you have to purchase.
A rectang around a block is simple use boundingbox.
nobody
  • .net stuff
« Reply #3 on: January 31, 2018, 01:14:53 PM »
Thanks all
