Author Topic: Updating value in a result buffer array.  (Read 2438 times)
tik
« on: January 12, 2012, 02:04:19 PM »
I have a ResultBuffer with XData in it. I want to update value in the ResultBuffer at a particular Index. I wrote a function to achieve that functionality but it is not working. I am passing the ResultBuffer as reference and disposing the ResultBuffer in the code that is calling this function. Can someone point to me what I am doing wrong.
public bool SetXDataAtIndex(ref ResultBuffer rb, int index, Object value)
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
                TypedValue val = new TypedValue();
                if (rb != null)
                    try
                        if (index >= rb.AsArray().Length)
                            return false;
                        val = new TypedValue(rb.AsArray()[index].TypeCode, value);
                        rb.AsArray()[index] = val;
                    catch (System.Exception)
                        return false;
                return true;
gile
  • Marseille, France
Re: Updating value in a result buffer array.
« Reply #1 on: January 12, 2012, 02:21:09 PM »
When doing :
you're changing the value in a TypedValue array object not in your ResultBuffer.
Try somethinf like this:
        public bool SetXDataAtIndex(ref ResultBuffer rb, int index, TypedValue val)
            TypedValue[] values = rb.AsArray();
            if (values.Length > index)
                values[index] = val;
                rb = new ResultBuffer(values);
                return true;
            return false;
« Last Edit: January 12, 2012, 02:35:09 PM by gile »
tik
« Reply #2 on: January 12, 2012, 02:28:23 PM »
Gile,
My idea was to update value at a given index in the TypedValue array and assign the new TypedValue array to the Result Buffer again. Sorry for using wrong terminology.
cincir
« Reply #3 on: January 13, 2012, 08:50:25 PM »
hi this is my first answer :)
you must create a new ResultBuffer and use your new TypedValue to create one. Because AsArray returns and array of TypedValues that are copies of the ones in ResultBuffer.
maybe something like this :
ResultBuffer newResultBuffer = new ResultBuffer();
TypedValue[] arrTypedValue = rb.AsArray();
for(int i = 0; i < arrTypedValue.Length ; i++)
     if (i == myIndex)
            newResultBuffer.Add(new TypedValue((int)DxfCode.something,something));
     else
            newResultBuffer.Add(arrTypedValue);
Hope this helps...
gile
  • Marseille, France
« Reply #4 on: January 14, 2012, 03:48:39 AM »
This is exactly what the code I posted does...
fixo
« Reply #5 on: January 14, 2012, 05:40:11 AM »
See quick example, you have to set the old TypeCode with new value
for partcular item in the ResultBuffer:
        public void ShowBuffer()
            Database db = doc.Database;
            Editor ed=doc.Editor;
            try
             ResultBuffer buf  = new ResultBuffer(new TypedValue[]
            { new TypedValue((int)DxfCode.Text, "ahha"),
               new TypedValue( (int)DxfCode.Real,1.2345),
            new TypedValue( (int)DxfCode.Int32,1000)});//old value
             TypedValue[] oldvalues = buf.AsArray();
            foreach (TypedValue tv in oldvalues)
                ed.WriteMessage("\nOld Value: {0}", tv.Value);
            int size = buf.AsArray().Length;
            int index = 1;
            object newvalue = 2000;// new value
                 TypedValue[] newvalues = new TypedValue[size];
               for (int n =0;n<size;n++)
                   if (n != index)
                       newvalues[n] = oldvalues[n];
                   else
                       // set new value by given idex:
                       newvalues[n] = new TypedValue((int)oldvalues[n].TypeCode, newvalue);
               buf = new ResultBuffer(newvalues);
               foreach (TypedValue tv in buf.AsArray())
                   ed.WriteMessage("\nNew Value: {0}", tv.Value);
            buf.Dispose();
                catch (System.Exception ex)
                    Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message + "\n" + ex.StackTrace);
                    //do nothing or display your message here
~'J'~
