Author Topic: autolisp exercise  (Read 8670 times)
Re: autolisp exercise
« Reply #15 on: January 09, 2006, 07:40:39 PM »
This is wordy due to my non concise coding style and inline comments, but hopefully Dan will find it illuminating ...
(defun c:foo ( / layername layerobj vportobj delta acadobj docobj )
    ;;  make / get the border layer
    (setq layerobj
        (vla-add
            (vla-get-layers
                (setq docobj
                    (vla-get-activedocument
                        (setq acadobj
                            (vlax-get-acad-object)
            (setq layername "Border")
    ;;  set the layer's properties as we see fit
    (foreach propertypair
            (Plottable . :vlax-false)
            (Freeze    . :vlax-false)
            (LayerOn   . :vlax-true)
            (Lock      . :vlax-false)
            (Color     . 251)
        (vlax-put-property
            layerobj
            (car propertypair)
            (cdr propertypair)
    ;;  switch to paperspace
    (vla-put-activespace docobj 0)
    ;;  switch to pspace
    (vla-put-mspace docobj :vlax-false)
    ;;  get the coords for the vport
    (initget 1)
    (setq p1 (getpoint "\nSelect the first corner of the vport: "))
    (initget 1)
    (setq p2 (getcorner p1 "Now the other corner: "))
    ;;  make the viewport
    (setq vportobj
        (vla-addpviewport
            (vla-get-paperspace docobj)
            (vlax-3d-point
                (mapcar
                   '(lambda (i) (/ i 2.0))
                    (mapcar '+ p1 p2)
            (car
                (setq delta
                    (mapcar
                       '(lambda (a b) (abs (- a b)))
                        p1
                        p2
            (cadr delta)
    ;;  change the vport's layer
    (vla-put-layer vportobj layername)
    ;;  make sure the vport is on
    (vla-display vportobj :vlax-true)
    ;;  switch to mspace
    (vla-put-mspace docobj :vlax-true)
    ;;  zoom extents to center the view
    (vla-zoomextents acadobj)
    ;;  now zoom relative to paperspace
    (vla-zoomscaled acadobj 0.5 acZoomScaledRelativePSpace)
    ;;  change back to pspace
    ;;  shhhh
« Last Edit: January 09, 2006, 11:24:20 PM by MP »
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
« Reply #16 on: January 09, 2006, 07:58:37 PM »
Your code makes me smile. 8-)
I've reached the age where the happy hour is a nap. (°Ώ°)
« Reply #17 on: January 09, 2006, 09:10:18 PM »
Makes me feel that all is well in the world, and that there is hope for mankind.
 :kewl:
when contemplating something so rational, how can it be otherwise.
« Reply #18 on: January 09, 2006, 09:14:57 PM »
.. except for the next to last comment :-)
« Reply #19 on: January 09, 2006, 09:53:43 PM »
CAB -- your comments make me smile. :)
Kerry, I dunno, I (failthfully) took my stupid pills today so yourlast  comment just confuses me.  :|
(But your first one is nice).
« Reply #20 on: January 09, 2006, 10:11:40 PM »
I took a double dose of my obtuse pill Michael .. you forgot the layer;P;  reading my comment now, it seems that I'm querying the pspace ..
thats my story, and I'm sticking with it   :lol:
added: You left that for Dan, right ?
« Reply #21 on: January 09, 2006, 10:18:40 PM »
There's no need -- I don't change the active layer.
:P
« Reply #22 on: January 09, 2006, 10:26:26 PM »
 :oops:
« Reply #23 on: January 09, 2006, 10:32:13 PM »
Man I've missed this place.
 :-D
LE
« Reply #24 on: January 09, 2006, 10:34:00 PM »
:oops:
What type of job.... the scoreboard does ?  it is only for AutoCAD 2006 ? :lol:
« Reply #25 on: January 09, 2006, 10:36:56 PM »
I assume you mean the piccy Luis ? That's ObjectDCL ..
LE
« Reply #26 on: January 09, 2006, 11:07:48 PM »
Oops.... I do not know what I was saying.....  :ugly:
« Reply #27 on: January 09, 2006, 11:13:17 PM »
heh, that's my speech :-)
ELOQUINTET
« Reply #28 on: January 10, 2006, 12:20:20 PM »
wow you guys have been chattin away in here. i'm so happy someone finally responded to one of my posts. i'll take a hard look at cab's and mps code thanks for your help guys.
