CAD Forums => CAD General => Topic started by: DanB on October 05, 2012, 11:09:56 AM
Every time I do this I think there might be a "better" way. Draw a line, any angle. Draw a second line perpendicular to the first line where the second line starts at the midpoint of the first line. This should create a "T" of sorts, lengths are not important for the excercise. I've always drawn the second line by starting a distance away from first, then back, perpendicular snap to the first line, move to midpoint. I'm not looking for a lisp routine or coding, just curious if there's a..different way..
Maybe not 'better', but another way might be to set UCS to object and turn Orthomode on.
Object snap tracking and polar tracking.
Command: line
Specify first point:
Specify next point or [Undo]:
Command: SNAPANG
Enter new value for SNAPANG <0>: Specify second point:
Command: line
Specify first point: mid
of
Specify next point or [Undo]: <Ortho on>
I know you said you weren't looking for code, but here is a short snippet which may streamline the process a little:
(defun c:per ( / *error* e o p )
(defun *error* ( m )
(if o (progn (setvar 'orthomode o) (command "_.ucs" "_p")))
(if (and
(setq p (getpoint "\nSpecify first point: "))
(setq e (car (nentselp p)))
(setq p (trans p 1 0))
(command "_.ucs" "_ob" e)
(setq o (getvar 'orthomode))
(setvar 'orthomode 1)
(command "_.line" "_non" (trans p 0 1))
(while (< 0 (getvar 'cmdactive)) (command "\\"))
(http://www.theswamp.org/lilly_pond/leemac/perpshortcut.gif)
Thanks all, always good to have a fresh look at some different methods. I like the snapang idea, going to try out Lee's code now.
grips!
pick line to highlight grips
pick midpoint
enter
enter (to get rotate)
c for copy
90 to rotate
enter
done!
Several in this tread.
http://www.theswamp.org/index.php?topic=1468.msg389018#msg389018
