Author Topic: Getting Area From Hatch Error  (Read 1473 times)
GDF
« on: December 20, 2019, 01:03:32 PM »
Ok, I sometimes get an error or crash using this code.
Yes, I'm stumped.
Here is another example for MP
Please help
GDF
Re: Getting Area From Hatch Error
« Reply #1 on: December 20, 2019, 01:13:10 PM »
Sorry, I forget this function:
;;;Victor Delgado  VDelgado@alhansen.com
(defun ARCH:UpdateBlocks  (BlockName AttTag AttVal / ssBlocks ssObjects Block)
  (setq ssBlocks (ssget "x" (list (cons 2 BlockName))))
  (if ssBlocks
    (progn (setq ssObjects
                  (vla-get-ActiveSelectionSet
                    (vla-get-ActiveDocument (vlax-get-acad-object))))
           (vlax-for
                  Block  ssObjects
             (foreach
                    Attribute  (vlax-invoke Block "GetAttributes")
               (if (= (vla-get-TagString Attribute) AttTag)
                 (vla-put-TextString Attribute AttVal))
               (vla-update Attribute)))))
  (princ))
(ARCH:UpdateBlocks "DRHortonTBH" "ADD" (vl-string-left-trim (substr (vl-filename-base (getvar "dwgname")) 1 16)
        (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 27))))
Dlanor
« Reply #2 on: December 20, 2019, 04:12:28 PM »
Error message ?
GDF
« Reply #3 on: December 20, 2019, 04:41:13 PM »
Can't divide by 0.
Or it would just crash...
Here is an example of what I modified:
           (if (= tot_areabrk nil)(setq tot_areabrk 0))
           (if (= tot_areasid nil)(setq tot_areasid 0))
           (if (= tot_areastn nil)(setq tot_areastn 0))
It seems to be working now...just a crude example of code.
