Author Topic: Urgent Viewport Help needed.  (Read 3093 times)
hudster
« on: August 09, 2004, 05:23:05 AM »
Is there a way I can rotate one of two viewports in a drawing whilst leaving the other unrotated?
I have a buildings with two wings, one at 35 degrees and on at 0 degrees, and I need to show both on a drawing at 0 degrees without changing either of the wings in model space.
any ideas?
  • Custom Title
« Reply #1 on: August 09, 2004, 06:05:41 AM »
Look at mvsetup.
Enter an option [Align/Create/Scale viewports/Options/Title block/Undo]: a
Enter an option [Angled/Horizontal/Vertical alignment/Rotate view/Undo]: r
Specify basepoint in the viewport with the view to be rotated: _endp of
Specify angle from basepoint:  <Ortho off> -35
hudster
« Reply #2 on: August 09, 2004, 06:06:39 AM »
I never even thoght of that.
thanks a lot.
 :D
  • Custom Title
« Reply #3 on: August 09, 2004, 06:08:45 AM »
42
« Reply #4 on: August 09, 2004, 07:14:27 AM »
Never let a day pass without learning something new.
Technical Director
Hunters South Architects
hendie
« Reply #5 on: August 09, 2004, 07:18:28 AM »
another option is to create a new ucs in the viewport and rotate your model to the required orientation.
CADaver
« Reply #6 on: August 09, 2004, 07:33:03 AM »
Quote from: hendie
After rotating the UCS to match the angle, use the PLAN command.
Another option is DVIEW TWIST.
