Author Topic: MultiLeaders  (Read 9093 times)
Krushert
  • FREE BEER Tomorrow!!
Re: MultiLeaders
« Reply #15 on: August 29, 2012, 07:20:45 AM »
I started playing with them at my last job just before I left.  They do not used them here but then again most people here use autocad as a dumb electronic pencil.  I keep showing them some of the new features and they accept some of the new feastures and reject others.
I should look into Mleaders some more.  Quick question though.  Can leaders style be set so that leaders alwyas connect to the text at certian points?  Here all text is left justfied and using regular leaders is a pain when editing text when the text is the left of the object beucase then the leader has to be edit to accomade the new text edits.   :realmad:
Krushert
Re: MultiLeaders
« Reply #16 on: August 29, 2012, 09:51:09 AM »
Okay so I am playing around with Mleaders which have led to additional questions.
see screen shot.  How do I make the style so that the text postion is always held (arrow 1 in screen shot)?  Right now every time I make a text edits or adjust the leaders landing it moves the text.
Second I need the leader attached toe the last word on the mulitline text and not the text box.  How do I do that?
  • Custom Title
Re: MultiLeaders
« Reply #17 on: August 29, 2012, 09:59:39 AM »
did you try "always left justify" under Content?
Jeff H
Re: MultiLeaders
« Reply #18 on: August 29, 2012, 10:01:47 AM »
How about 'Extend leader to text'.
Krushert
Re: MultiLeaders
« Reply #19 on: August 29, 2012, 10:50:41 AM »
Yes on the left justify and I do not have that button  Running ACA 2011.
Re: MultiLeaders
« Reply #20 on: August 29, 2012, 11:02:13 AM »
Since you don't have the option to extend the leader to the text, perhaps setting the Horizontal attachment to 'Underline bottom line' might be an acceptable compromise.
Krushert
Re: MultiLeaders
« Reply #21 on: August 29, 2012, 11:18:11 AM »
Not with these guys.  or me for that matter!
What version are you using Jeff?
StykFacE
Re: MultiLeaders
« Reply #22 on: August 29, 2012, 11:52:36 AM »
Another thing I like about Multileaders.... once you have one set, click the Multileader once, right-click, select "Add Leader". Create as many extra leaders and when you move the text box all the connected leaders dynamically adjust.
Drafter X
Re: MultiLeaders
« Reply #23 on: August 29, 2012, 01:01:49 PM »
Love multileaders and never use old style leaders... EVER!
I'll try to post how mine are set up, I use a user defined block for a finish callout and a multiline attribute for clarification under it. With a field in the finish callout that I link to a 'room info' block I can change all the finish tags in a room or a whole job uber easy.
AND.. if I must say, they look quite pretty, I use a drop shadow so they have 'depth' on the page and my clients love how they present to their clients.
CadJockey Militia Commander
StykFacE
Re: MultiLeaders
« Reply #24 on: August 29, 2012, 01:08:11 PM »
"Drop Shadow"? Can you give an example? I'm interested in this.  :kewl:
Drafter X
Re: MultiLeaders
« Reply #25 on: August 29, 2012, 01:13:02 PM »
 :-D
I'll post an example later, can't access those particular drawings where I am right now.
Matt__W
  • I like my water diluted.
Re: MultiLeaders
« Reply #26 on: August 29, 2012, 01:14:35 PM »
http://en.wikipedia.org/wiki/Drop_shadow
Autodesk Expert Elite
Jeff H
Re: MultiLeaders
« Reply #27 on: August 29, 2012, 01:32:53 PM »
pic from 2013, but just opened 2012 and it also has the option.
That option does give you the desired results.
Re: MultiLeaders
« Reply #28 on: August 29, 2012, 02:48:16 PM »
Then you had better upgrade!  :-D
Krushert
Re: MultiLeaders
« Reply #29 on: August 29, 2012, 03:06:29 PM »
Yeah, I am going to bug the boss tomorrow.  Before I started here I was using 2012 and liked it very much.
