Author Topic: blocks then text  (Read 2017 times)
CADEC70
blocks then text
« on: January 11, 2008, 10:14:04 PM »
I inserted a block..what I wanted to do is put the name of the block by just clicking the 'block'. Say I created a chair block, then inserted it on a drawing, then I want to put the label on it, by just simply clicking on the chair.
AND
Can it be on MTEXT?
is it possible to make the justification on 'middle centre'
and automatically rotate on 90 if the block is rotated
Thanks in advance
TimSpangler
  • CAD Naked!!
Re: blocks then text
« Reply #1 on: January 12, 2008, 12:08:15 PM »
Constant attribute?
ACA 2015 - Windows 7 Pro
« Reply #2 on: January 12, 2008, 01:03:45 PM »
One could use a field, and select OBJECT> then pick the chair block>the select the block name.
adalea03
« Reply #3 on: January 13, 2008, 08:00:16 AM »
Try code below.
;Places block name as text object; text is scaled to match dimension text
(defun c:bnn  (/ bname mynv-lst)
  (setq mynv-lst (mapcar '(lambda (x) (list x (getvar x)))
    '("clayer" "dimscale" "cmdecho" "osmode" "orthomode")))
  (setvar "cmdecho" 0) (setvar "osmode" 0) (setvar "orthomode" 0)
  (setq bname (vlax-get-property (vlax-ename->vla-object
    (car (entsel "\nSelect block to label:"))) "name"))
;;;  (setq bname (substr  1 (- (strlen bn) 2)))
  (command "mtext" (getpoint "\nSelect point for block name:")
           "h" (* (getvar "dimtxt") (getvar "dimscale"))
           "j" "mc" "w" 0 bname "")
  (command "move" (entlast) "" (getvar "lastpoint") "\\")
  (mapcar '(lambda (x) (setvar (car x) (cadr x))) mynv-lst)
CADEC70
« Reply #4 on: January 18, 2008, 01:06:57 PM »
Thanks!
Can I have another request,..is it possible to set the mtext width automatically after adding the text?
Thanks in advance
adalea03
« Reply #5 on: January 20, 2008, 09:12:15 AM »
Did you try to edit the previous code?
Try to change the zero (after the "w") in the mtext command.
Also, the code should have had a (vl-load-com) statement near the begining.
Tony
adalea03
« Reply #6 on: January 20, 2008, 09:34:33 AM »
  (vl-load-com) ;added
;;; I use the next line of code to strip a 2 character suffix from our block names
;;; I have commented it here so that it doesn't strip 2 characters
;;; the next line scales the mtext height to match dimension text
           "j" "mc"
;;; the next line sets the width, change the zero to your liking
           "w" 0
           bname "")
;;; I use the next line to tweak the placement of the label
Oops. Forgot to add the code to last post.
Tony
CADEC70
« Reply #7 on: January 21, 2008, 12:36:24 PM »
Sorry I'm not really a lisp guy...
so
I try to use the above lisp code, but you can't set the 'mtext width'
Thanks in advance
adalea03
« Reply #8 on: January 21, 2008, 09:24:27 PM »
Each of the commands below will create mtext objects with different widths.
Copy and paste each one to the command line (press the enter key after each paste).
When done , select all the new text objects and observe the different widths.
           "j" "mc"
           "w" 12
           "my block name" "")
           "j" "mc"
           "w" 22
           "my block name" "")
           "j" "mc"
           "w" 44
           "my block name" "")
           "j" "mc"
           "w" 88
           "my block name" "")
If I have misunderstood your request, I may only be confusing the issue.
Hopefully, I don't lead you too far astray before a real "Swamper' pipes in.
