Author Topic: Objectdbx.. image path  (Read 7624 times)
HelpLispinSeattle
Re: Objectdbx.. image path
« Reply #15 on: January 16, 2009, 02:35:16 PM »
Tim,
I caught my mistake. I'm a little embarrass to tell you.
I was repathing to a non existing location. As soon as
I created the desired location & copied the images it
worked.
Thank you for your time & tip for error handling. Keep
up the good work!
« Reply #16 on: January 16, 2009, 02:36:54 PM »
Tim,
worked.
up the good work!
We all have made mistakes like that.  Glad you caught it on your own, and you're welcome for the help/tips I provided.  You also keep up the good work.  As long as you are willing to learn, there are smart people here willing to teach.
JCUTRONA
« Reply #17 on: January 27, 2009, 02:42:09 PM »
Tim,
worked.
up the good work!
Now that is rich.  True sense of community.
Maverick®
« Reply #18 on: January 27, 2009, 02:43:29 PM »
And I'm here too!  :-D
dustinthiesse
« Reply #19 on: January 27, 2009, 04:12:12 PM »
Tim,
worked.
up the good work!
Probably the main reason I like this forum so much!
MSTG007
« Reply #20 on: January 27, 2017, 03:57:57 PM »
I know this is an OLD topic. I was messing around with the idea. Its a neat concept. However, with my awesome skill level. I keep getting an error. I am sure.... wait... I know I did something to make it not work.
(PutImagePath "c:\\temp\\test.dwg" "..\\Image\\")
Command: (PutImagePath "c:\\temp\\test.dwg" "..\\Image\\")
 Error-> Automation Error. File access error
thanks for any ideas!
Civil3D 2020
« Reply #21 on: February 09, 2017, 09:33:33 AM »
In my testing, it looks like a valid image has to be in the new location.
Command: (putimagepath "c:/test/images/image.dwg" "../images/")
Command: (putimagepath "c:/test/image.dwg" "../images/")
Command: (putimagepath "c:/test/image.dwg" "../images")
Command: (putimagepath "c:/test/image.dwg" "/images/")
Command: (putimagepath "c:/test/image.dwg" "./images/")
Command: (putimagepath "c:/test/dwg/image.dwg" "../images/")
My testing setup looked like
c:/test/
 |- dwg/
      |- image.dwg
 |- images/
      |- image.dwg
MSTG007
« Reply #22 on: February 09, 2017, 09:37:20 AM »
Just curious here, so there is not a way that it can copy the source "image" from where ever and place it in the new folder image and repath?
Civil3D 2020
« Reply #23 on: February 09, 2017, 09:44:20 AM »
A routine could be written, but as this one stands. No.  It only repaths images, and within the new path there has to be a valid file (at least that is what I get from my quick testing).
MSTG007
« Reply #24 on: February 09, 2017, 09:47:17 AM »
Interesting... Thank you for sharing. Looks like I will "lol" looking for something that may do this. Thank you for the suggestion.
Its amazing... I know how people work on projects and attach images from other projects or what not; but to have it copy the images attached in a dwg to a \images\ folder makes sense.
Civil3D 2020
