Author Topic: How to distribute a setting of one layout to all ?  (Read 2440 times)
Coder
« on: November 22, 2011, 04:25:32 AM »
Hello .
I made a setting for one layout for printing , and I would like to distribute these settings to all layouts in the same drawing .
It is the same as when you invoke the print command and chose <previous plot> from the Page setup -> name in print dialog box .
Is it possible with Lisp ?
Thank you
alanjt
  • Standby for witty remark...
Re: How to distribute a setting of one layout to all ?
« Reply #1 on: November 22, 2011, 06:13:13 AM »
http://www.theswamp.org/index.php?topic=38005.msg430212#msg430212
http://www.theswamp.org/index.php?topic=8855.msg113482#msg113482
If you create the pagesetup within the plot dialog, doesn't it give you the option to apply to all layouts?
Dropbox
Coder
« Reply #2 on: November 22, 2011, 06:47:23 AM »
Thank you so much , that's works just fine . :-)
