Author Topic: Display number color of objects  (Read 3737 times)
irneb
Re: Display number color of objects
« Reply #15 on: August 17, 2011, 12:40:18 PM »
Or even a smaller change:
;;  CAB/Recursive version
(defun _GetColour (e / c)
  (if (setq c (cdr (assoc 62 e)))
       (cdr
         (assoc c
                  (0 . "ByBlock")
                  (1 . "Red")
                  (2 . "Yellow")
                  (3 . "Green")
                  (4 . "Cyan")
                  (5 . "Blue")
                  (6 . "Magenta")
                  (7 . "White")
      ((itoa c))
    (strcat "ByLayer -> " (_GetColour (tblsearch "LAYER" (cdr (assoc 8 e))))) ;Irné change to recursive
    ;;  CAB change
