Ok, so I found a zoom2txt lisp file.
What I can do is make a copy of all room name blocks in a different area and on a non plotting layer. Use express tools to explode the attributes to text. Then I could move the explode blocks with text back to the original location. Then use the zoom2txt routine to zoom to that text.
Round about way of doing it. But, it works.
However... again... I have hundreds of these to do and having an automated way of zooming to a text string or attribute based on the current "ctab" value would be most helpful. Especially if it could do the layout creation and viewport zooming to the current tab name.
Now that would be awesome.
Thanks again.
;;TIP : ZOOM2TXT.LSP (C)1993, Jeffrey R. Foster, Jr.
(defun c:zoom2txt (/ chgtxt zoompt1 zoompt2 sstxt sstxtlen txtent1 txtins dwgscal
pt1 pt3 num embed zoomnext txtent1 txtstyl txtlay txtinspt
txt_elev txt_height txt_rotate txt_obliq txt_width txt_color
txt_2_chg txt_chg)
(setq txt (getstring T "\nEnter text string to zoom to: "))
(initget 1 "Y N")
(setq embed (getkword "\nSearch for embedded strings? <Y or N>: "))
(if (= embed "Y")
(setq txt (strcat "*" txt "*"))
(setq zoompt1 (getvar "extmin"))
(setq zoompt2 (getvar "extmax"))
(setq search_list
(list
(cons 0 "text")
(cons 1 txt)
(if (/= (setq sstxt (ssget "X" search_list)) nil)
(setq sstxtlen (sslength sstxt))
(alert (strcat "\nThere are " (itoa sstxtlen) " text entities meeting your criteria"))
(setq
txtent1 (entget (ssname sstxt 0))
txtins (cdr (assoc '10 txtent1))
dwgscal (getvar "ltscale")
pt1 (list (- (car txtins) (* 1.0 dwgscal))
(- (cadr txtins) (* 1.0 dwgscal))
pt3 (list (+ (car txtins) (* 1.0 dwgscal))
(+ (cadr txtins) (* 1.0 dwgscal))
(command "_zoom" "w" pt1 pt3)
(initget 1 "T P N")
(setq chgtxt (getkword "\nEdit Text, text Properties or Neither? <T P N>: "))
(cond ((= chgtxt "T") (command "_ddedit" (ssname sstxt 0) ""))
((= chgtxt "P") (txt_prop))
((= chgtxt "N") (setq num 1))
(setq num 1)
(if (> sstxtlen 1)
(initget 1 "Y N")
(while (and (/= (setq zoomnext (getkword "\nZoom to next string? <Y or N>: ")) "N") (< num sstxtlen))
(ssdel (ssname sstxt 0) sstxt)
(setq
(initget 1 "T P N")
(setq num (+ num 1))
(initget 1 "Y N")
(command "_zoom" zoompt1 zoompt2)
(alert (strcat "\nThe text string ,"txt", does not exist in this drawing... Sorry!!!"))
(Defun txt_prop ()
(setq
txt_styl (cdr (assoc '7 (entget (ssname sstxt 0))))
txt_lay (cdr (assoc '8 (entget (ssname sstxt 0))))
txt_inspt (cdr (assoc '10 (entget (ssname sstxt 0))))
txt_elev (cdr (assoc '38 (entget (ssname sstxt 0))))
txt_height (cdr (assoc '40 (entget (ssname sstxt 0))))
txt_width (cdr (assoc '41 (entget (ssname sstxt 0))))
txt_rotate (cdr (assoc '50 (entget (ssname sstxt 0))))
txt_obliq (cdr (assoc '51 (entget (ssname sstxt 0))))
txt_color (cdr (assoc '62 (entget (ssname sstxt 0))))
(prompt (strcat "\nCurrent text Style is : " txt_styl))
(prompt (strcat "\nCurrent text Layer is : " txt_lay))
(prompt (strcat "\nCurrent text Insertion point: "
(if (< (car txt_inspt) 0.0)
(strcat "-" (rtos (abs (car txt_inspt)) 2 4))
(rtos (car txt_inspt) 2 4)
(if (< (cadr txt_inspt) 0.0)
(strcat "-" (rtos (abs (cadr txt_inspt)) 2 4))
(rtos (cadr txt_inspt) 2 4)
(if (< (nth 2 txt_inspt) 0.0)
(strcat "-" (rtos (abs (nth 2 txt_inspt)) 2 4))
(rtos (nth 2 txt_inspt) 2 4)
(if (/= txt_elev nil)
(prompt (strcat "\nCurrent text Elevation is : " (rtos txt_elev 2 4)))
(prompt "\nCurrent text elevation is : 0")
(prompt (strcat "\nCurrent text Height is : " (rtos txt_height 2 4)))
(prompt (strcat "\nCurrent text Width is : " (rtos txt_width 2 4)))
(prompt (strcat "\nCurrent text Rotation angle is : " (rtos txt_rotate 2 4)))
(prompt (strcat "\nCurrent text Obliquing angle is : " (rtos txt_obliq 2 4)))
(if (/= txt_color nil)
(prompt (strcat "\nCurrent text Color is : " (rtos txt_color 2 4)))
(prompt "\nCurrent text color is : Bylayer")
(setq txt_2_chg 1)
(while (/= txt_2_chg "Q")
(initget "S L I E H W R O C Q")
(setq txt_2_chg (getkword "\nChange which property -
Style,Layer,Insertion point,Elev,Height,Width,Rotation,Oblique angle,Color, or Quit: "))
((= txt_2_chg "S")
(command "style" "?" "*")
(setq txt_styl (getstring "\nWhich text style do you wish to use? : "))
(txt_2_make)
((= txt_2_chg "L")
(alert "\nLook for the layer you wish")
(command "_ddlmodes")
(setq txt_lay (getstring "\nWhich text layer do you wish to use? : "))
(txt_2_make)
((= txt_2_chg "I")
(setq txt_inspt (getpoint "\nPick new text insertion point: "))
(txt_2_make)
((= txt_2_chg "E")
(setq txt_elev (getreal "\nEnter the text elevation you wish to use: "))
(txt_2_make)
((= txt_2_chg "H")
(setq txt_height (getreal "\nEnter the text height you wish to use: "))
(txt_2_make)
((= txt_2_chg "W")
(setq txt_width (getreal "\nEnter the text width you wish to use: "))
(txt_2_make)
((= txt_2_chg "R")
(setq txt_rotate (getangle "\nEnter or pick the text rotation you wish to use: "))
(txt_2_make)
((= txt_2_chg "O")
(setq txt_obliq (* (/ (getreal "\nEnter the text obliquing angle you wish to use: ") 180.0) PI))
(txt_2_make)
((= txt_2_chg "C")
(setq txt_color (getreal "\nEnter the number for the text color you wish to use: "))
(txt_2_make)
(defun txt_2_make ()
(setq txt_chg (entget (ssname sstxt 0)))
(setq txt_chg (subst (cons 7 txt_styl) (assoc 7 txt_chg) txt_chg))
(entmod txt_chg)
(setq txt_chg (subst (cons 8 txt_lay) (assoc 8 txt_chg) txt_chg))
(entmod txt_chg)
(setq txt_chg (subst (cons 10 txt_inspt) (assoc 10 txt_chg) txt_chg))
(entmod txt_chg)
(setq txt_chg (subst (cons 38 txt_elev) (assoc 38 txt_chg) txt_chg))
(entmod txt_chg)
(setq txt_chg (subst (cons 40 txt_height) (assoc 40 txt_chg) txt_chg))
(entmod txt_chg)
(setq txt_chg (subst (cons 41 txt_width) (assoc 41 txt_chg) txt_chg))
(entmod txt_chg)
(setq txt_chg (subst (cons 50 txt_rotate) (assoc 50 txt_chg) txt_chg))
(entmod txt_chg)
(setq txt_chg (subst (cons 51 txt_obliq) (assoc 51 txt_chg) txt_chg))
(entmod txt_chg)
(setq txt_chg (subst (cons 62 txt_color) (assoc 62 txt_color) txt_chg))
(entmod txt_chg)
