Author Topic: IExtensionApplication.Terminate() called on fatal error  (Read 2421 times)
Jeff H
« on: October 12, 2012, 05:29:36 AM »
Does IExtensionApplication.Terminate() get called on fatal errors?
Maybe your app or AutoCAD caused the error but does anyone have examples where it was not called?
huiz
  • Certified Prof C3D
Re: IExtensionApplication.Terminate() called on fatal error
« Reply #1 on: October 12, 2012, 06:49:11 AM »
I'm not sure. Can't you create a fatal error (editing a line which is read only or something like that) and see what happens?
I always use a Try..Catch and log the error in a logfile in the Catch part. If something is wrong during initializing I get the error at least via the logfile, because AutoCAD kills the process silently in the Initialize part.
Jeff H
« Reply #2 on: October 12, 2012, 07:05:19 AM »
I could, but was trying to get feedback from others if consistent.
TheMaster
« Reply #3 on: October 12, 2012, 01:27:04 PM »
I very much doubt that it is, although it could depend on how AutoCAD terminates. If there's a dialog that asks if you want to save the file (which rarely succeeds), it might, but with the more unceremonious forms of termination, it's very unlikely.
