Author Topic: AutoCAD text...to word..  (Read 3134 times)
Andrea
« on: April 19, 2006, 03:43:26 PM »
Hi all..
Is it possible to export AutoCAD "DTEXT" in a word or txt file ??
thanks.
Keep smile...
Re: AutoCAD text...to word..
« Reply #1 on: April 19, 2006, 03:50:18 PM »
yes
CottageCGirl
« Reply #2 on: April 19, 2006, 03:55:28 PM »
yes
now, that's helpful...isn't it..... :?
« Reply #3 on: April 19, 2006, 04:35:32 PM »
To open a file for writing;
(setq file_open (open "c:\\name.txt" "w"))then you want to write to it using;
(write-line "some string" file_open)when you're done make sure you close the file
(close file_open)
that's a start anyway.
« Reply #4 on: April 19, 2006, 05:04:43 PM »
and because it's in my contract ..
(DEFUN c:txtexport (/ ss ent fh fn hnd index sslen txt)
   ;; codehimbelonga kwb@theSwamp
   (IF (SETQ ss (SSGET '((0 . "TEXT"))))
      (PROGN (SETQ index 0
                   sslen (SSLENGTH ss)
                   fn  (GETFILED "Text Export/Append to File" "" "txt" 1)
             (IF  fn
                (PROGN (SETQ fh (OPEN fn "a"))
                       (WHILE (< index sslen)
                          (SETQ hnd (SSNAME ss index)
                                ent (ENTGET hnd)
                                txt (CDR (ASSOC 1 ent))
                                index (1+ index)
                          (PRINC (STRCAT txt "\n") fh)
                       (CLOSE fh)
   (PRINC)
« Reply #5 on: April 19, 2006, 05:31:02 PM »
 :lmao:
« Reply #6 on: April 19, 2006, 07:15:49 PM »
or, a little more efficient, if it makes a difference ..
(DEFUN c:txtexport (/ ss  fh fn sslen index )
   (IF (AND (SETQ ss (SSGET '((0 . "TEXT"))))
            (SETQ fn (GETFILED "Text Export/Append to File" "" "txt" 1))
      (PROGN
               index -1
               sslen (SSLENGTH ss)
         (WHILE (< (SETQ index (1+ index)) sslen)
            (PRINC (STRCAT (CDR (ASSOC 1 (ENTGET (SSNAME ss index)))) "\n") fh)
         (CLOSE fh)
   (PRINC)
« Last Edit: April 19, 2006, 07:26:30 PM by Kerry Brown »
LE
« Reply #7 on: April 19, 2006, 07:36:06 PM »
For the $75 USD an hour Mark is paying.... you can also provide the way to do as RTF file no?
« Reply #8 on: April 19, 2006, 07:53:20 PM »
hehehehe
with the right incentive, I can provide almost anything    :lol:
sometimes just having my sense of humour appreciated is enough.
Slim©
  • The Dude Abides...
« Reply #9 on: April 19, 2006, 10:49:10 PM »
Sounds like someone is looking for a raise in pay.....
Arizona
« Reply #10 on: April 20, 2006, 06:28:27 AM »
hehehehe
You have a great sense of humor!!! Are you twice as funny in person? By that I mean, are we missing all the facial expressions, etc...
« Reply #11 on: April 20, 2006, 06:57:20 PM »
don't believe the advertising Arizona, I'm really a grouch .. just sometimes act a little silly or see the rediculous is a situation that isn't there. There is a medical term for it, but the word is too hard to spell.
« Reply #12 on: April 21, 2006, 09:03:50 PM »
 ... and you're welcome Andrea , any time.
« Reply #13 on: April 21, 2006, 09:23:58 PM »
 stop... your killing me :lmao:
- John Carmack
- J.R.R. Tolkien
