Author Topic: MText Editor - Project Exercise  (Read 9078 times)
LE
« on: November 29, 2006, 11:47:38 PM »
The idea for this alternative MText Editor is to implement new or existing features using an User Interface and mostly to get into the C# world as much as possible...
using System;
using System.ComponentModel;
using System.Data;
using System.Text;
using System.IO;
using Autodesk.AutoCAD.Windows;
using System.Text.RegularExpressions;
using System.Runtime.InteropServices;
using System.Threading;
using System.Globalization;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using MTextEditor;
[assembly: CommandClass(typeof(ClassLibrary.LESQClass))]
namespace ClassLibrary
    /// <summary>
    /// Summary description for LESQClass.
    /// </summary>
    public class LESQClass
        //static string x ;
        public LESQClass()
            // TODO: Add constructor logic here
        [CommandMethod("MTED")]
        static public void mtexteditor()
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            //doc.BeginDoubleClick += new _DAcadDocumentEvents_BeginDoubleClickEventHandler(m_doc_BeginDoubleClick);
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptEntityResult res = ed.GetEntity("\nSelect a MText: ");
            if (res.Status != PromptStatus.OK) return;
                MText text = tr.GetObject(res.ObjectId, OpenMode.ForWrite, false) as MText;
                if (text == null) return;
                string origText = text.Contents;
                using (MTextForm form = new MTextForm())
                    form.SaveMyString(origText);
                    form.Contents = text.Contents;
                    acadApp.ShowModalDialog(form);
                    text.Contents = form.Contents;
                tr.Commit();
using System;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.Collections;
namespace MTextEditor
    public partial class MTextForm :  Form
        //ArrayList stringList = new ArrayList();
        string[] lista = new string[3];
        public MTextForm()
            InitializeComponent();
        // remove color from the mtext
        private void OnClick_RemoveColor(object sender, EventArgs e)
            //Editor ed = acadApp.DocumentManager.MdiActiveDocument.Editor;
            string txtstr = textBox1.Text;
            char[] s = txtstr.ToCharArray();
            int cont = 0, flag = 0;
            string txt1 = "";
            for (int j = 0; j < txtstr.Length; j++)
                try
                    char let = s[cont];
                    if (let == '\\')
                        if (char.ToUpper(s[cont + 1]) == 'C')
                            int i = (cont + 2);
                            while (s[i] != ';')
                                i++;
                            // remove true and book colors
                            if (s[i + 1] == '\\' && s[i + 2] == 'c')
                                i = i + 2;
                                while (s[i] != ';')
                                    i++;
                            txt1 = txt1 + s[i + 1];
                            cont = i + 2;
                        else
                            flag = 1;
                    else // color format found
                        txt1 = txt1 + let;
                        // remove the color blocks
                        int found;
                        found = txt1.IndexOf("{");
                        if (found >= 0)
                            txt1 = txt1.Remove(found, 1);
                        found = txt1.IndexOf("}");
                        if (found >= 0)
                        cont = 1 + cont;
                    // no color format found
                    if (flag == 1)
                        txt1 = txt1 + let;
                        cont = 1 + cont;
                        flag = 0;
                catch
                    //ed.WriteMessage("Error");
            textBox1.Text = txt1; // change the contents
        private void button2_Click(object sender, EventArgs e)
            //this.Close();
        public string Contents
            get { return textBox1.Text; }
            set { textBox1.Text = value; }
        private void MTextForm_Load(object sender, EventArgs e)
            textBox1.Focus();
            textBox1.SelectAll(); // onLoad form select all text
        public string GetMyString()
            string s = lista[0];
            return s;
        private void OnClick_Exit(object sender, EventArgs e)
            textBox1.Text = GetMyString();
            Close();
        public void SaveMyString(string s)
            lista[0] = s;
        private void MTextForm_Close(object sender, FormClosedEventArgs e)
        //public void CopyAllMyText()
        //    if (textBox1.SelectionLength == 0)
        //        textBox1.SelectAll();
        //    //textBox1.Copy();
Adding:
Included is the VS2005 SLN - in case someone find it useful ... Your comments/feedback are welcome. Have fun
Adding:
User Interface
« Last Edit: November 30, 2006, 12:10:24 AM by LE »
Glenn R
Re: MText Editor - Project Exercise
« Reply #1 on: November 30, 2006, 12:37:32 AM »
Great start on your C# stuff Luis. Attached is your code with some of my changes.
You'll notice I added another constructor to your form.
Anyway, have a look.
Cheers,
Glenn.
« Reply #2 on: November 30, 2006, 01:14:29 AM »
great stuff Luis ..
You might want to have a look at one of Tony's samples too ..
he <the master> refers to Dimensions, but I ran something similar against conventional MText
"Tony Tanzillo" wrote <tony.tanzillo@THE_URL_BELOW.com> wrote in message news:<5401749@discussion.autodesk.com>...
You can strip the formatting info from the
MTEXT object in the dimension block definition.
See http://www.caddzone.com/MTextFragmentSample.cs for an example.
I added this line for the dialog :
WinForms.MessageBox.Show("\n" + mtext.Contents + "\n" + s_data );
with this result :
« Reply #3 on: November 30, 2006, 01:17:39 AM »
oh, the 'WinForms' is defined from this  :
using WinForms = System.Windows.Forms;
Glenn R
« Reply #4 on: November 30, 2006, 01:28:31 AM »
Kerry, out of interest, put a few "hard returns" in your mtext string and run Tony's sample over it.
From memory it throws big fat exceptions...
Glenn R
« Reply #5 on: November 30, 2006, 01:30:40 AM »
A friend and I recently had to look at stripping/replacing formatting codes in MText to get it to go to MicroStation...it's not a particularly easy exercise when you consider there are a LOT of combinations.
I definately think regular expressions would be the way to go for this sort of thing.
« Reply #6 on: November 30, 2006, 01:41:29 AM »
Glenn, there are a few issues with the Sample, but it's a start.
Yes,  Formatting translation is a real pain. We wrote some cpp stuff about 7 or 8 years ago ... going to have to do it again for C#. Considering we had a VLisp version running perfectly well at the time there is definite cause to question my sanity.
« Reply #7 on: November 30, 2006, 01:50:27 AM »
Glenn,
I just edited the Mtext ... added a few hard returns .... NO issues with it exploding  in AC2007.
There is an issue 'cause its doing what it's told .. ie removing the \P 's when I'd expect that they be replaced with a space .. but thats a procedural thing.
LE
« Reply #8 on: November 30, 2006, 09:19:54 AM »
Thank you Kerry for the url link, I'll check the sample.
When I wrote the first sample using the explodeFragments() - in ObjectARX - I got the fragments in between text lines, for example if one word has two colors let say... (no big deal - and since the idea was to provide different ways to remove the color format from a MText - I moved into C++, Lisp and now C#)
LE
« Reply #9 on: November 30, 2006, 09:36:20 AM »
Cheers,
Glenn.
Great, I am now testing the solution with the new changes... now I do not have the undo in case the x button on the form and another I have to exit without making any changes...
That's why I was using the GetMyString and SaveMyString functions... I know in C# they are the get/set to get or change attributes, I need to read more about them...
LE
« Reply #10 on: November 30, 2006, 12:57:59 PM »
Changes were made to the original code, here is the latest...
                using (MTextForm form = new MTextForm(origText))
                    // save original text
                    form.OrigMText = origText;
                tr.Commit();
        private string orig;
        public string OrigMText
            get { return orig; }
            set { orig = value; }
        public MTextForm()
public MTextForm(string mtextContents) : this()
textBox1.Text = mtextContents;
            string txt1 = "";
                try
                    char let = s[cont];
                    if (let == '\\')
                            int i = (cont + 2);
                            while (s[i] != ';')
                                i++;
                                i = i + 2;
                                while (s[i] != ';')
                                    i++;
                            cont = i + 2;
                        else
                            flag = 1;
                        txt1 = txt1 + let;
                        int found;
                        if (found >= 0)
                        if (found >= 0)
                        cont = 1 + cont;
                    if (flag == 1) // no color format found
                        txt1 = txt1 + let;
                        cont = 1 + cont;
                        flag = 0;
                catch{}
            textBox1.Focus();
        private void MTextForm_Closed(object sender, FormClosedEventArgs e)
            textBox1.Text = OrigMText;
        private void OnClick_ApplyChanges(object sender, EventArgs e)
            textBox1.Text = Contents;
            OrigMText = Contents;
            Close();
TO-DO:
1. Add one button to undo the mtext with the original contents (showing the color formatting)
2. Add the Uppercase, Lowercase, Uppercase first characters.
LE
« Reply #11 on: November 30, 2006, 02:26:31 PM »
Here is the function to change to proper case the contents of the mtext.
It goes into the MTextForm class - and by adding an OnClick event into one of the supplied buttons on the form
private void OnClick_ProperCase(object sender, EventArgs e)
    // get the actual text on the textbox
    string str = Contents;
    string strPCase = str.Substring(0, 1).ToUpper();
    str = str.Substring(1).ToLower();
    string strP = "";
    for (int i=0; i<str.Length; i++)
        if (i > 1)
            strP = str.Substring(i - 1, 1);
        if (strP.Equals(" ") ||
            strP.Equals("\t") ||
            strP.Equals("\n") ||
            strP.Equals("."))
            strPCase += str.Substring(i, 1).ToUpper();
        else
            strPCase += str.Substring(i, 1);
    // set back the new text to the textbox
    textBox1.Text = strPCase;
Not fully tested - if a mtext has color formatting or maybe any other format - it will remove that text portion - so requires more tests and update to the function.
To make it work, please first run the removal of color format and then the proper case...
TO-DO:
Work on more types of formatting - not just the color -
LE
« Reply #12 on: November 30, 2006, 03:31:51 PM »
Actually what it does is that changes the color format to lower case and that changes the color - when converting to proper case each word...
I added in the filter condition the comparison for the ";" - that will turn a word to proper case ie:
this is {\C2;only} a test of a {\C6;proper} {\C105;\c5881664;case} mtext
The word proper to Proper (as it does to the whole paragraph... I need to find a way to avoid the turn to lowercase the formatting code....
This is the result on the dialog, when the proper case option is called:
This Is {\c2;Only} A Test Of A {\c6;Proper} {\c105;\c5881664;Case} Mtext
See, it does the job, but changes the color formatting to lowercase to...
                    strP.Equals(".") ||
                    strP.Equals(";")) //<<<-----
« Last Edit: November 30, 2006, 03:37:18 PM by LE »
LE
« Reply #13 on: November 30, 2006, 03:51:13 PM »
While I am working on this, does anyone knows why the title bar icon does not show the one applied... (mt.ico)... for some reason - I could not make it to work... it brings the a2007 one...
Other... it will be a good idea to implement a reactor when touching a MText... I have to read more about this.... appart of all the namespace, any one required for that in particular? - I have seen interop or something like that....
Glenn R
« Reply #14 on: November 30, 2006, 05:47:18 PM »
As far as the form icon goes Luis, I've never gotten it to work in either 2005, 6 or 7. I suspect AutoCAD overrides it...no biggy.
