Author Topic: ToolStripLabel1.Text when use ToolStripProgressBar  (Read 2555 times)
Humbertogo
« on: March 05, 2008, 10:36:56 AM »
why don't update ToolStripLabel1.Text
Public Class Form1
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        ToolStripProgressBar1.Minimum = 0
        ToolStripProgressBar1.Maximum = 200
        ToolStripProgressBar1.Value = 0
        ToolStripProgressBar1.Step = 1
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim cnt As Long
        For cnt = 1 To 200
            If ToolStripProgressBar1.Value < 200 Then
                Debug.Print(cnt)
                ToolStripProgressBar1.Value = cnt
                ToolStripProgressBar1.PerformStep()
                ToolStripLabel1.Text = cnt
            Else
            End If
        Next
    End Sub
End Class
StefanDidak
Re: ToolStripLabel1.Text when use ToolStripProgressBar
« Reply #1 on: March 05, 2008, 02:58:24 PM »
You might want to call Application.DoEvents() and see if the label updates.
