fatty,
i tried this and noticed that you hard coded my schedule name into the code which i don't want to use for testing. i tried to change the line back to dat.xls and now it no longer works. it opens the excel file but does not go back into autocad. when i maximize the autocad window it say interrupted by used. i even tried opening the dat.xls file before running the routine but still doesn't work, what is going on?
Hi Dan, sorry for the late
After the Excel file window will be minimized,
you can just click on AutoCAD icon at the bottom
of screen, I tried to do it programmable with using
of API function 'Setfocus' and with VBA AppActivate
function, but with no luck at the moment
Just for interest, why do you wan't to test it
on Excel file you sent me?
I tested it on this file only, please try with this file
and send your comments back
Unforunatelly I haven't have a 2008 version
maybe problem is on
~'J'~
