Is this a good solution?
; (ALE_String_AfterBeforeDelimiter "123/45/1/2/999 H=9876 W - Foo1" "H=" " ") => "9876"
; (ALE_String_AfterBeforeDelimiter "123/45/1/2/999 H=9876 W - Foo1" "H=" "j") => "9876 W - Foo1"
; (ALE_String_AfterBeforeDelimiter "123/45/1/2/999 H=9876 W - Foo1" "x=" "j") => nil
; return nil if first Delimiter not found
; if second Delimiter not found return all string after first Delimiter
(defun ALE_String_AfterBeforeDelimiter (InpStr FrtDlm ScdDlm / SttPos EndPos)
(if (setq SttPos (vl-string-search FrtDlm InpStr))
(if (setq EndPos (vl-string-search ScdDlm InpStr (+ SttPos (strlen FrtDlm))))
(substr InpStr (+ 1 SttPos (strlen FrtDlm)) (- EndPos SttPos (strlen ScdDlm) 1))
(substr InpStr (+ 1 SttPos (strlen FrtDlm)))
