Author Topic: How to freeze a list of layers?  (Read 6220 times)
scottcd
« on: September 30, 2008, 08:02:50 AM »
I have the following list of layers (filtered_layerlist)
("G8010001" "G8010004" "G8010010" "G8010015" "G8010021" "G8010026" "G8010027"
"G8010030" "G8010032" "G8010035" "G8010036" "G8010052" "G8010057" "G8010059"
"G8010071" "G8010072" "G8010098" "G8010321" "G8010374" "G8010376" "G8010382"
"G8010388" "G8010397" "G8010400" "G8010570" "G8010572" "G8011000" "G8011005"
"G8011006" "G8011009" "G8011010")
     I was trying to use the following to freeze all the layers in the above list
 (mapcar '(lambda (x) (command "layer" "freeze" x "") filtered_layerlist))
But I know the syntax is not correct for a start - can anyone give me a push in the right direction.
Cheers
Scott
AutoCAD Dos R9 - 2018 and BricCAD 18.2
kpblc
Re: How to freeze a list of layers?
« Reply #1 on: September 30, 2008, 08:26:58 AM »
(setq layers '("G8010001"      "G8010004"      "G8010010"      "G8010015"
               "G8010021"      "G8010026"      "G8010027"      "G8010030"
               "G8010057"      "G8010059"      "G8010071"      "G8010072"
               "G8010382"      "G8010388"      "G8010397"      "G8010400"
      ) ;_ end of setq
(defun test (lst / adoc)
  (vla-startundomark
    (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
    ) ;_ end of vla-StartUndoMark
  (foreach item lst
    (vl-catch-all-apply
      (function
        (lambda ()
          (vla-put-freeze (vla-item (vla-get-layers adoc) item) :vlax-true)
          ) ;_ end of lambda
        ) ;_ end of function
      ) ;_ end of vl-catch-all-apply
    ) ;_ end of foreach
  (vla-endundomark adoc)
  ) ;_ end of defun
Sorry for my English.
« Reply #2 on: September 30, 2008, 08:42:54 AM »
If you're going to use the COMMAND, this will do.
(defun c:test()
(setq lst
       '("G8010001" "G8010004" "G8010010" "G8010015" "G8010021" "G8010026" "G8010027"
"G8011006" "G8011009" "G8011010"))
  (setq str "")
  (mapcar '(lambda(x) (setq str (strcat str x ","))) lst)
  (command "_-layer" "_F" str "")
Another version
(command "._Layer")
(mapcar '(lambda (x) (command "_f" x)) laylst)
(command "")
scottcd
« Reply #3 on: September 30, 2008, 08:49:49 AM »
Thanks for both suggestions.  :-) :-)
Is there any reason to prefer one version over the other?
Cheers
Scott
scottcd
« Reply #4 on: September 30, 2008, 08:56:28 AM »
Thanks Cab,
I have used your second version - short and sweet!
I didn't know that you could put code in the middle of a command call like that :grazy:
Cheers
Scott
« Reply #5 on: September 30, 2008, 08:57:44 AM »
« Reply #6 on: September 30, 2008, 09:05:19 AM »
Cheers
Scott
The COMMAND version is often slower than the code version.
The COMMAND version may stop working with a different version of ACAD IF they change the
order of the prompts or the key word.
The COMMAND version is usually shorter code and easy for the novice to create.
Some programmers see the COMMAND version as SCRIPT writing and not real programing.  :-)
GDF
« Reply #7 on: September 30, 2008, 10:23:00 AM »
Thanks guys, I've learned something this morning.
I use the command version instead of a script now for controlling my layers in xrefs.
(defun c:1ST  (/ 1st str)
  (setq lst '("*DEF*" "*|A-ALT-WIND-2" "*|A-ALT-WIND-3" "*|A-AREA*" "*|A-CLNG*"
              "*|A-DOOR-CODE" "*|A-DIMS*" "*|JUNK" "*|A-NOTE*" "*|A-PATT*"
              "*A-SHTT*" "*|A-SYMB*" "*|LS*" "*|X-LINE*"))
  (setq str "")
  (mapcar '(lambda (x) (setq str (strcat str x ","))) lst)
  (command "_-layer" "_T" "*|A-ALT-WIND-1" "")
  (princ))
(defun c:3RD  (/ 1st str)
  (setq lst '("*DEF*" "*|A-ALT-WIND-1" "*|A-ALT-WIND-3" "*|A-AREA*" "*|A-CLNG*"
  (setq str "")
  (command "_-layer" "_T" "*|A-ALT-WIND-2" "")
  (princ))
Gary
« Reply #8 on: September 30, 2008, 10:51:29 AM »
One more method:
http://www.theswamp.org/index.php?topic=690.msg16138#msg16138
CHA-CHING! ...That's where that code snip i had in my notes came from; i had my suspicions a bit of code i had in a file was from Stig, but now i have the proof.
Thanx CAB.
*[Se7en:] runs off to locate and comment code.*
Andrea
« Reply #9 on: September 30, 2008, 12:41:00 PM »
I think that You need to verify if the layer exist before..
and verify if you aren't to a layer who need to be freeze
You can not freeze current layer.
(setq layerlisttofreeze
(foreach l layerlisttofreeze
  (if (and
(not (eq (strcase (getvar "CLAYER")) (strcase l)))
(member (strcase l) (mapcar 'strcase (ai_table "LAYER" 4)))
    (vl-cmdf "._-Layer" "_F" l "")
Keep smile...
« Reply #10 on: September 30, 2008, 01:14:21 PM »
The layer command doesn't care if the layer exist or not and will ignore the current layer but will notify you of the fact.
« Reply #11 on: September 30, 2008, 01:20:03 PM »
Command, vl-cmdf are SLOW! Please dont use them. Use either entmod or vl property functions to preform your operations.
that's only cause your using ``command''.  Use entmod and you can (I wouldn't recommend it but...):
( (lambda ( / laylst )
   (setq laylst (entget (tblobjname "LAYER" (getvar 'CLAYER))))
   (entmod
    (subst
     (cons 70 (boole 6 (cdr (assoc 70 laylst)) 1))
     (assoc 70 laylst)
     laylst))) )
Andrea
« Reply #12 on: September 30, 2008, 01:21:29 PM »
you'r right CAB,
  (if (member (strcase l) (mapcar 'strcase (ai_table "LAYER" 4)))
Keep smile...
« Reply #13 on: September 30, 2008, 01:28:33 PM »
Just for the sake of conversation (Assuming the following code was a valid solution):
Why are you issuing the ``command'' over and over again for the list of layers? The layer command takes a list of layers...comma separated. Your taking a slow process and making it even slower!
« Reply #14 on: September 30, 2008, 01:42:09 PM »
Command: [color=red]-LA[/color]
-LAYER
Current layer:  "0"
Enter an option
[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte]:[color=red] F[/color]
Enter name list of layer(s) to freeze or <select objects>: [color=red]G8*[/color]
Enter an option
