Author Topic: Autocad Import command  (Read 2317 times)
hobbs1210
  • Mosquito
« on: April 22, 2018, 10:12:46 AM »
I am currently working on a way to import inventor ipt files into Autocad using C#. Im currently using  AcadDocument.sendcommand, but this requires user interaction. Is there an alternative ways to interface with the import command?
WILL HATCH
Re: Autocad Import command
« Reply #1 on: April 23, 2018, 02:30:14 AM »
Define requires user interaction?
Beyond setting filedia to 0? (I've never used the import .ipt feature)
hobbs1210
  • Mosquito
« Reply #2 on: April 23, 2018, 12:12:48 PM »
"Processing background job" dialog would pop up requiring the user to close it.
lamarn
« Reply #3 on: April 23, 2018, 05:38:04 PM »
This inventor import functionality will not work if your Inventor files come from a later version than the AutoCAD version.
It would be nice if user would get a notification of that. But it doesn't.
Design is something you should do with both hands. My 2d hand , my 3d hand ..
ChrisCarlson
« Reply #4 on: April 26, 2018, 08:31:04 AM »
You'll have to play with the hidden message settings of FixedProfile.
http://adndevblog.typepad.com/autocad/2013/07/disable-task-dialogs-programmatically.html
BIGAL
  • 40 + years of using Autocad
« Reply #5 on: April 27, 2018, 03:10:26 AM »
In lisp a lot of the Command type can be run manually with some file dia and a - sign eg -line try it as -import.
