Fatty,
Nice routine but the problem is with the original text. It is not as you expected.
The actual text is "(2060.72 sqft)", so you see you can't assume the string ends with "ft"
That was the problem with Peters routine. The actual string criteria was not known we he
wrote his routine. Another note, the default should be 0.9 as RoyalChill made a typo I think.
