Author Topic: Help - Export Software for Civil 3D  (Read 2384 times)
nobody
  • .net stuff
« on: May 02, 2016, 11:32:29 PM »
I need software that will essentially take a civil 3d drawing, bind everything, purge everything, burst the blocks, and explode AEC objects so they become standard objects to export for various utility agencies I work with still stuck in the dark ages (using 2007 autocad bahaha)...
Anyone know of anything?
huiz
  • Certified Prof C3D
Re: Help - Export Software for Civil 3D
« Reply #1 on: May 03, 2016, 01:49:54 AM »
ExportToAutoCAD does not the trick?
You can also export to PDF and import that in AutoCAD :-)
lamarn
« Reply #2 on: May 03, 2016, 02:43:45 AM »
Besides 'EXPORTTOAUTOCAD' you may find it usefull to take a look at FME.
It can read DWG and has some nice processing features to get to GIS.
https://www.safe.com/transformers/dwg-styler/
« Last Edit: May 03, 2016, 04:53:01 AM by lamarn »
Design is something you should do with both hands. My 2d hand , my 3d hand ..
nobody
  • .net stuff
« Reply #3 on: May 03, 2016, 09:44:29 AM »
Thanks..I'll take a look
