Author Topic: Deleting temporary files at control disposal  (Read 2083 times)
« on: October 04, 2010, 05:21:42 PM »
I have not quite figured this out, and I am sure there is a solution that I have not found .. that seems to be the case ..
I've built a usercontrol and embedded about half a dozen files required for control to operate as expected. When the control is loaded, the needed resources are extracted to the users temporary folder, modified, loaded etc ...
When the application housing the usercontrol ends, presumably it calls the Dispose method of the control, which is where I located the IO.File.Delete(tempfile) call ... but the temp file isn't being deleted, in fact the Dispose method is never called .. at least I can't tell that it has been called.
If these files were in the main application, I would simply delete the files when the form is closing ... I'll be using this control in other applications in the future and I would like it to clean up after itself.
Any suggestions?
Jeff H
Re: Deleting temporary files at control disposal
« Reply #1 on: October 04, 2010, 07:19:05 PM »
public partial class UserControl1 : UserControl, IDisposable // Implement Idisposable to force
        public UserControl1()
            InitializeComponent();
        //Destructor code to run when object is disposed
        ~UserControl1()
        //using blah // Will automatically call Dispose method for objects who class that implements IDisposable
        #region IDisposable Members
        public void Dispose()
             GC.SuppressFinalize(this);
        #endregion
  [CommandMethod("Disposeee")]
        public static void Disposeee()
            System.Windows.Forms.UserControl uc = new System.Windows.Forms.UserControl();
            if (uc != null)
                uc.Dispose();
******EDITED*************
« Last Edit: October 04, 2010, 07:28:55 PM by Jeff H »
« Reply #2 on: October 05, 2010, 12:42:58 AM »
Got it, works like a champ
I wish everything was as simple as this ...
