Author Topic: Best way to compare 2 drawings  (Read 4825 times)
MSTG007
« on: April 03, 2015, 09:04:09 AM »
I can not think of a way to compare two drawings. I want to be able compare the layers states of both (Color / On-off / thaw / etc.). What is the best way I can get a print out and compare what is difference between the two?
Thanks guys
Civil3D 2020
Re: Best way to compare 2 drawings
« Reply #1 on: April 03, 2015, 09:12:09 AM »
You just want to compare the layers?
MSTG007
« Reply #2 on: April 03, 2015, 09:13:10 AM »
Yup, on PDF or something. I need to show people what is being changed.
Civil3D 2020
« Reply #3 on: April 03, 2015, 09:15:35 AM »
So what if some linework changed on the two files?
MSTG007
« Reply #4 on: April 03, 2015, 09:16:33 AM »
I don't think that will be a big deal. What are you thinking of?
Civil3D 2020
« Reply #5 on: April 03, 2015, 09:21:09 AM »
What I do to see 'changes' is open the old drawing, change all the layer colors to RED. Then xref the new drawing over top and change all the XREF colors to BLUE. Not high tech but has worked for me for many years.
« Reply #6 on: April 03, 2015, 09:21:24 AM »
export the Layerstate(s)
Import them into EXCEL....place columns side by side on a pivot table to compare settings
OR
Use one file as a Standard...
compare against the other
the standards report will show what is different (not to standard)
MSTG007
« Reply #7 on: April 03, 2015, 09:23:39 AM »
I did not know you can export the layer state into excel. The two drawings have the same Named Layers but the colors - on - off are different.
Civil3D 2020
danallen
« Reply #8 on: April 03, 2015, 10:59:51 AM »
Bluebeam has a PDF compare tool that will do color overlay of changes. Also will auto-cloud.
« Reply #9 on: April 03, 2015, 11:18:38 AM »
Import Data...from TXT
the formatting is messy but it will import.
Upon thinking about it the Cad Standards checker is probably the better option
as it would allow comparing a >>> b
and b >>>>a
just to catch difference (changes) in either direction
MSTG007
« Reply #10 on: April 03, 2015, 11:19:57 AM »
Thanks man. I will check that out shortly!
Civil3D 2020
Krushert
  • FREE BEER Tomorrow!!
« Reply #11 on: April 03, 2015, 11:29:37 AM »
I do not know it this will help barbecue I think it just compares geometry but it might have something.
AutoCAD Architecture has Drawing Compare.  I played with it but not seriously put it work.  So I really can not give an opinion on it.
There is plug-in for regular AutoCAD
Bethrine
« Reply #12 on: April 03, 2015, 12:18:33 PM »
Either you are hungary or maybe your spell checker is out-dated?  :lol:
Krushert
« Reply #13 on: April 03, 2015, 01:10:30 PM »
No the spell checker is hungry not hungary!   :-D :tongue2:
Bethrine
« Reply #14 on: April 03, 2015, 01:29:15 PM »
 :woow: :blink:  :2funny:  :crazy2:
