Author Topic: Test Points  (Read 2098 times)
A_LOTA_NOTA
Test Points
« on: October 03, 2007, 06:28:34 PM »
If I had the user pick to points using....
(setq Pt1 (getpoint "\nSpecify first corner: "))
  (setq Pt2 (getcorner Pt1 "Specify opposite corner: "))
How could I test to see if the window was taller then it is wide?
Re: Test Points
« Reply #1 on: October 03, 2007, 06:31:26 PM »
(setq xDist (abs (- (car Pt1) (car Pt2))))
(setq yDist (abs (- (cadr Pt1) (cadr Pt2))))
(if (> xDist yDist)
 (prompt "\n Longer than taller.")
 (prompt "\n Taller than longer.")
Re: Test Points
« Reply #2 on: October 03, 2007, 07:06:22 PM »
Tim you forgot one.
 ((= xDist yDist)
  (prompt "\n Window is just right."))
 ((> xDist yDist)
  (prompt "\n Longer than taller."))
 (t
  (prompt "\n Taller than longer."))
:lmao:
Re: Test Points
« Reply #3 on: October 03, 2007, 07:10:04 PM »
Tim you forgot one.
 ((= xDist yDist)
 ((> xDist yDist)
 (t
:lmao:
Oh Alan...... At least correct me the correct way.  :wink:
 ((equal xDist yDist 0.000001)
 ((> xDist yDist)
 (t
:lmao:  Good one though......
Re: Test Points
« Reply #4 on: October 03, 2007, 07:25:21 PM »
Never meant for it to be used, just a vehicle for some lame humor. No correction intended.
Re: Test Points
« Reply #5 on: October 03, 2007, 10:15:25 PM »
I took it as such, and I needed it today.  Thanks.  :-D
gile
  • Marseille, France
Re: Test Points
« Reply #6 on: October 04, 2007, 01:49:11 AM »
Just for fun, using grread, grvecs and grtext to display the result in real time on the status line
((lambda ()
   (setq pt1 (getpoint "\nFirst corner: "))
   (princ pt1)
   (princ "\nOpposite corner: ")
   (while (and (setq gr (grread T 4 0)) (/= (car gr) 3))
     (redraw)
     (setq pt2 (cadr gr)
   xd  (abs (- (car pt1) (car pt2)))
   yd  (abs (- (cadr pt1) (cadr pt2)))
     (grvecs (list (list (car pt1) (cadr pt1))
   (list (car pt2) (cadr pt1))
   (list (car pt2) (cadr pt2))
   (list (car pt1) (cadr pt2))
       ((< xd yd) (grtext -1 "Taller than longer"))
       ((< yd xd) (grtext -1 "Longer than taller"))
       (T (grtext -1 "Perfect square"))
   (grtext)
   (princ pt2)
