Anyone know of a lisp/dcl/vba app that I can use to enter bearings and distances. I have an old school client that uses an HP calc program to enter his points which he then prints out... which has the northing easting on it.
I know about using something like:
@132.06<N00D08'23"
type of command line. I am hoping to make it relatively easy to enter the bearings and then label the bearing line. I am trying to find something that would actually read the txt files he outputs or enter the coords easily, there is some coding that is not compatible. Trying to avoid having to retype his entries.
This is a small client and I just want to be able to meet his needs... cheaply.
Yes. I do know I can use my Revit Structural Suite 2010 to enter bearings and such. But, it would be nice to have the ability in good ol vanilla autocad.
I have a routine to label the bearing and distance above and below a selected line. I guess a nice dcl or vba to simply enter the bearing numbers and not the d/m/s would be easy enough. Something like that.
Of course... ideas and suggestions are always welcome.
Trying to be diversified enough to have work...which I am sure you all know is hard to come by now.
Thanks in advance. I can post more info if you need it.
AutoCAD Structural Detailing 2010
AutoCAD 2010
My client uses an HP48GX calculator which is then connected to an old Win98 machine which is run in dos mode to read the data from the HP calculator. See the sample output file.
%%HP: T(3)A(D)F(.);
{ { 51 } {
[ 1000 1000 0 ]
[ 983.998709465 1055.17663637 0 ]
[ 691.067915851 970.226355898 0 ]
[ 914.129786383 1178.23693716 0 ]
[ 861.620525524 1223.08364239 0 ]
[ 823.891941539 1244.78559941 0 ]
[ 797.762363154 1190.77407163 0 ]
[ 691.228625012 969.674135533 0 ]
"" } 0 {
[ 871.601242784 1162.9519948 0 ]
"" } 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 {
[ 983.842735179 1055.71447652 0 ]
"" } 0 {
[ 914.431681482 1177.53321179 0 ]
[ 862.257101291 1222.20979698 0 ]
[ 862.270107747 1222.20098794 0 ]
"" } 0 0 0 0 0 0 0
0 0 0 0 0 0 0 }
