Author Topic: Isolate Objects - Block Being Disobediant  (Read 5500 times)
Hugh_Compton
« on: October 27, 2008, 12:25:34 PM »
I have a routine for Isolating selected objects.  It works fine BUT not on blocks.  If I try to use it on a block the block will disappear.  can anyone help?
<CommandMethod("isom")> _
    Public Sub objectsIsolate()
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim tm As Autodesk.AutoCAD.ApplicationServices.TransactionManager = db.TransactionManager
        Dim ss As SelectionSet
        Dim ent As Entity = Nothing
        Dim trans As Transaction = tm.StartTransaction()
        Try
            Dim bt As BlockTable = tm.GetObject(db.BlockTableId, OpenMode.ForRead, False)
            Dim btr As BlockTableRecord = tm.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead, False, True)
            'Get objectIds from user selection
            Dim prmptSSopt As New PromptSelectionOptions()
            prmptSSopt.PrepareOptionalDetails = True
            prmptSSopt.RejectObjectsOnLockedLayers = False
            prmptSSopt.MessageForAdding = "Select objects to isolate: " + vbNewLine
            Dim ssRes As PromptSelectionResult = ed.GetSelection(prmptSSopt)
            If Not ssRes.Status = PromptStatus.OK Then Exit Sub
            ss = ssRes.Value
            'make an array of objectIds from the user's selection set
            Dim objIds() As ObjectId = ss.GetObjectIds()
            'Make everything visible = false
            For Each id As ObjectId In btr 'For Each id In drawing
                ent = CType(trans.GetObject(id, OpenMode.ForWrite, False), Entity)
                ent.Visible = False
            Next
            'Make Users selection visible
            For Each objId As ObjectId In objIds
                ent = CType(trans.GetObject(objId, OpenMode.ForWrite, False, True), Entity)
                ent.Visible = True
            Next
        Catch ex As System.Exception
            MsgBox(ex.Message, MsgBoxStyle.Information, "Error in Isolate")
        Finally
            trans.Commit()
            trans.Dispose()
        End Try
Glenn R
Re: Isolate Objects - Block Being Disobediant
« Reply #1 on: October 27, 2008, 12:38:11 PM »
Test drawing?
Hugh_Compton
« Reply #2 on: October 27, 2008, 12:43:46 PM »
OK, I've attached one....the cylinder is a block.....the circle is a circle entity.....
Glenn R
« Reply #3 on: October 27, 2008, 04:46:45 PM »
Uhhh...why are you using an objects Visible property to isolate it?
« Reply #4 on: October 27, 2008, 04:51:10 PM »
That is how I have done it in Lisp without problems.  Is there a better way?
Hugh_Compton
« Reply #5 on: October 28, 2008, 04:37:48 AM »
By Isolate I mean make only the objects that a user selects will be visible in the application's window.  I believe it has something to do with getting the objectIds of objects within the block.  I thought it might be a common problem so have posted it here.  I am still investigating and will post a solution if I find one.
Glenn R
« Reply #6 on: October 28, 2008, 06:23:01 AM »
I for one would definitely not be doing it this way for several reasons:
1. If your program fails, you need code to get back the objects turned off.
2. Confusing to the user as they would use layers.
3. Use layers instead.
If you must continue down this route, try separating the loop to turn the selected objects visible out into it's own transaction and see what happens with that as an initial step.
Glenn R
« Reply #7 on: October 28, 2008, 06:24:51 AM »
You also don't mention:
Visual Studio version
.NET Framework version
AutoCAD version
Glenn R
« Reply #8 on: October 28, 2008, 07:01:53 AM »
The below works for me on your test drawing on the cylinder. I am using AutoCAD 2009, Visual C# 2008 Express and .Net Framework 3.5:
[CommandMethod("MakeInvisible", CommandFlags.NoPaperSpace)]
        public static void MakeInvisibleCommand()
            PromptSelectionOptions pso = new PromptSelectionOptions();
            pso.RejectObjectsOnLockedLayers = false;
            pso.MessageForAdding = "Select objects to isolate: ";
            pso.MessageForRemoval = "Select objects to remove: ";
            Editor ed = doc.Editor;
            Database db = doc.Database;
            // ask the question
            PromptSelectionResult psr = ed.GetSelection(pso);
            if (psr.Status != PromptStatus.OK)
                return;
                BlockTableRecord modelspaceBTR = tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead, false) as BlockTableRecord;
                if (modelspaceBTR == null)
                    return;
                foreach (ObjectId btrId in modelspaceBTR)
                    Entity modelspaceEnt = tr.GetObject(btrId, OpenMode.ForWrite, false) as Entity;
                    if (modelspaceEnt == null)
                        continue;
                    modelspaceEnt.Visible = false;
                ObjectId[] selectedIds = psr.Value.GetObjectIds();
                foreach (ObjectId selectedId in selectedIds)
                    Entity modelspaceEnt = tr.GetObject(selectedId, OpenMode.ForWrite, false) as Entity;
                        continue;
                    modelspaceEnt.Visible = true;
                tr.Commit();
« Reply #9 on: October 28, 2008, 07:32:49 AM »
interesting, prmptSSopt.PrepareOptionalDetails = true;  was the problem  :-o
« Reply #10 on: October 28, 2008, 07:35:54 AM »
here is another approach
CommandMethod("doit")]
    static public void doit()
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      try
        PromptSelectionOptions prmptSSopt = new PromptSelectionOptions();
        //prmptSSopt.PrepareOptionalDetails = true;
        prmptSSopt.RejectObjectsOnLockedLayers = false;
        prmptSSopt.MessageForAdding = "\nSelect objects to isolate: ";
        PromptSelectionResult ssRes = ed.GetSelection(prmptSSopt);
        if (ssRes.Status != PromptStatus.OK)
          return;
        SelectionSet ss = ssRes.Value;
        List<ObjectId> ids = new List<ObjectId>(ss.GetObjectIds());
        AcDb.TransactionManager manager = db.TransactionManager;
        using (Transaction transaction = manager.StartTransaction())
          BlockTableRecord btr = transaction.GetObject
            (SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead) as BlockTableRecord;
          foreach (ObjectId id in btr)
            Entity ent = transaction.GetObject(id, OpenMode.ForWrite) as Entity;
            if (ent != null && !(ids.Contains(id)))
              ent.Visible = false;
          transaction.Commit();
      catch (System.Exception ex)
        ed.WriteMessage("\n" + ex.Message);
        ed.WriteMessage("\n" + ex.StackTrace);
Glenn R
« Reply #11 on: October 28, 2008, 07:36:03 AM »
More than likely as it sets the ':N' option of acedSSGet.
That was pretty much my only difference to the original code Dan.
« Reply #12 on: October 28, 2008, 07:37:21 AM »
Thanks master Glenn, this one had me stumped to. PS do you know the ARX equivalent of prmptSSopt.PrepareOptionalDetails?
« Reply #13 on: October 28, 2008, 07:37:41 AM »
 :lol:
Glenn R
« Reply #14 on: October 28, 2008, 07:38:56 AM »
Does the above explain it Dan? :)
