Author Topic: alot of if statements  (Read 2013 times)
andrew_nao
« on: January 19, 2011, 09:56:40 AM »
I have alot of "if" statements
(if (= blockname "fmta12k6")
     (load "a-xprt")
that look like this
I know i can put them all in a cond statement but how do i get it to load the lisp files in the cond
Re: alot of if statements
« Reply #1 on: January 19, 2011, 10:10:17 AM »
    (eq blockname "fmta12k6")
    (load "a-xprt")
  ( (eq blockname ...
« Reply #2 on: January 19, 2011, 10:18:40 AM »
If you have a bunch of these you could also lump them into a list and use ASSOC to load:
(setq lst '(("fmta12k6" . "a-xprt")
    ("fmta12k6_2" . "a-xprt_2")
    ("fmta12k6_3" . "a-xprt_3")
    ("fmta12k6_4" . "a-xprt_4")
;;Assoc is case sensitive
(if (setq tmp (assoc blockname lst))
  (load (cdr tmp))
andrew_nao
« Reply #3 on: January 20, 2011, 08:38:56 AM »
gah!
I had left the progn in my cond statements, thats why it didnt work for me.  :ugly:
thanks all for the help
« Reply #4 on: January 20, 2011, 12:05:47 PM »
The progn is ok to use but you may have placed it incorrectly.
This should still work:
    (progn (load "a-xprt"))
  ( (eq blockname ...
alanjt
  • Standby for witty remark...
« Reply #5 on: January 20, 2011, 01:40:18 PM »
Side note, but still relevant: one should fill the second argument to ensure that an error is not thrown.
eg.
Command: (load "bread.lsp")
Error: LOAD failed: "bread.lsp"
Command: (load "bread.lsp" nil)
nil
Command: (load "bread.lsp" "you want bread, three dollars! no soup for you!")
I prefer the nil option since I can then use a logical evaluation (or, and, if, etc.) to see if the desired routine actually loaded, since if loaded, it will return the symbol of the last loaded routine in the loaded file.
eg.
Command: (load "toggle.lsp" nil)
C:SSM
eg. (evaluation)
Command: (and (load "chicken.lsp" nil)) <<Nothing loaded, nil returned
nil
Command: (and (load "toggle.lsp" nil)) <<Code loaded, T returned
T
Dropbox
« Reply #6 on: January 20, 2011, 01:58:25 PM »
Good point Alan.  8-)
VovKa
  • Ukraine
« Reply #7 on: January 20, 2011, 02:00:58 PM »
what if the last symbol is nil? or the last expression evaluates to nil? :)
i use
(= (setq tmp (vk_RandNum)) (load "toggle" tmp))
