Author Topic: Challenge: get an updated viewdir  (Read 3126 times)
Bryco
« on: October 14, 2006, 03:32:29 PM »
Vba doesn't seem to have a way to get an updated viewdir, I'm hoping lisp has the wherewithall.
By updated I mean like viewctr, you pan or zoom and you get a new one.
Re: Challenge: get an updated viewdir
« Reply #1 on: October 14, 2006, 05:27:54 PM »
Not sure but are you looking for dxf code 16?
16   View direction from target point (in WCS)
       DXF: X value; APP: 3D point
I did not see the vlisp property for this.
When the vp is active (getvar "VIEWDIR") returns ir for the vp.
Within paper space this will return it.
(cdr (assoc 16 (entget (car(entsel)))))
« Last Edit: October 14, 2006, 05:30:09 PM by CAB »
Bryco
« Reply #2 on: October 14, 2006, 05:58:37 PM »
Cab, I'm using this in modelspace. Neither this (16)  or the getvar "viewdir" update with pan or zoom , (nor does target) but calling the camera command will show a new target and new camera.
 VIEWDIR System Variable
Stores the viewing direction in the current viewport expressed in UCS coordinates.
This describes the camera point as a 3D offset from the target point.
( The length from zero to the viewdir point=length of camera-target so I'm after the new length)
