Author Topic: Marko ,Please have a look ! Draw trapezoid on the face of 3d solid  (Read 2499 times)
andy_lee
Hi guys
Can make this routine draw trapezoid on the face of 3d solid ?
Here is draw isosceles trapezoid
code was at:  http://www.cadtutor.net/forum/showthread.php?88383-Draw-an-isosceles-trapezoid
  1. (defun c:Test (/ dtr ac ab p sl a b c d e p)
  2.   ;;    Author : Tharwat Al Shoufi                      ;;
  3.   ;; Draw Trapezoid with angle 55 on the two sides      ;;
  4.   ;; -------------------------------------------------- ;;
  5.   (defun dtr (a) (* pi (/ a 180.0)))
  6.   (if (not *traplen*)
  7.     (setq *traplen* 10.0)
  8.   )
  9.   (if (not *traphgt*)
  10.     (setq *traphgt* 4.0)
  11.   )
  12.   (if (and (setq *traplen* (cond ((getdist (strcat "\n Specify Length of Trapezoid < " (rtos *traplen* 2 2) " > :")))
  13.                                  (*traplen*)
  14.                            )
  15.            )
  16.            (setq *traphgt* (cond ((getdist (strcat "\n Specify Height of Trapezoid < " (rtos *traphgt* 2 2) " > :")))
  17.                                  (*traphgt*)
  18.                            )
  19.            )
  20.            (setq ac (/ *traphgt* (sin (dtr 55.)))
  21.                  ab (* ac (cos (dtr 55.)))
  22.            )
  23.            (if (>= (setq sl (- *traplen* (+ ab ab))) 0.)
  24.              (setq p (getpoint "\n Specify top center point of Trapezoid :"))
  25.              (progn (alert "Length of Trapezoid is too small !!") nil)
  26.            )
  27.       )
  28.     (progn (setq a (polar p pi (/ sl 2.))
  29.                  b (polar a (dtr 235.) ac)
  30.                  c (polar b 0. *traplen*)
  31.                  d (polar c (dtr 125.) ac)
  32.                  e (entmakex
  33.                      (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(90 . 4) '(70 . 1))
  34.                              (mapcar '(lambda (pt) (cons 10 (list (car pt) (cadr pt)))) (list a b c d))
  35.                      )
  36.                    )
  37.            )
  38.     )
  39.   )
  40.   (if e
  41.     (command "_.rotate" e "" "_non" p "\\")
  42.   )
  43.   (princ)
  44. )
  45.
Reference image  from other member. Thanks.
« Last Edit: July 28, 2015, 10:11:05 AM by andy_lee »
andy.
Best regards.
andy_lee
Re: Draw trapezoid on the face of 3d solid
« Reply #1 on: July 28, 2015, 10:04:51 AM »
@ribarm
Hi marko.
I know you are great with 3D models. I need you have a look. :-)
andy.
Best regards.
ribarm
  • Marko Ribar, architect
Re: Marko ,Please have a look ! Draw trapezoid on the face of 3d solid
« Reply #2 on: July 28, 2015, 10:51:28 AM »
You have to experiment for a while to get used to...
  1. (defun c:Test ( / dtr ac ab p sl a b c d e p ucsf cmde )
  8.   )
  11.   )
  12.   (if (not (eq (getvar 'worlducs) 1))
  13.     (progn
  14.       (command "_.UCS" "_W")
  15.       (setq ucsf t)
  16.     )
  17.   )
  18.   (if (and (setq *traplen* (cond ((getdist (strcat "\n Specify Length of Trapezoid < " (rtos *traplen* 2 2) " > :")))
  19.                                  (*traplen*)
  20.                            )
  21.            )
  22.            (setq *traphgt* (cond ((getdist (strcat "\n Specify Height of Trapezoid < " (rtos *traphgt* 2 2) " > :")))
  23.                                  (*traphgt*)
  24.                            )
  25.            )
  26.            (setq ac (/ *traphgt* (sin (dtr 55.)))
  27.                  ab (* ac (cos (dtr 55.)))
  28.            )
  29.            (if (>= (setq sl (- *traplen* (+ ab ab))) 0.)
  30.              (setq p (getpoint "\n Specify top center point of Trapezoid :"))
  31.              (progn (alert "Length of Trapezoid is too small !!") nil)
  32.            )
  33.       )
  34.     (progn (setq a (polar p pi (/ sl 2.))
  35.                  b (polar a (dtr 235.) ac)
  36.                  c (polar b 0. *traplen*)
  37.                  d (polar c (dtr 125.) ac)
  38.                  e (entmakex
  39.                      (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(90 . 4) '(70 . 1))
  40.                              (mapcar '(lambda (pt) (cons 10 (list (car pt) (cadr pt)))) (list a b c d))
  41.                      )
  42.                    )
  43.            )
  44.     )
  45.   )
  46.   (setq cmde (getvar 'cmdecho))
  47.   (setvar 'cmdecho 1)
  48.   (if e
  49.     (progn
  50.       (command "_.copybase" "_non" p e "" "")
  51.       (entdel e)
  52.       (prompt "\nPick face of 3D solid (edge which is parallel to Trapezoid top edge), then adjust UCS further more (Xflip, Yflip, next face if wrong picked) and then press ENTER to accept...")
  53.       (command "_.UCS" "_F")
  54.       (while (< 0 (getvar 'cmdactive)) (command "\\"))
  55.       (setq p (getpoint "\nPick or specify top center point to place Trapezoid : "))
  56.       (command "_.pasteclip" "_non" p)
  57.     )
  58.   )
  59.   (command "_.UCS" "_P")
  60.   (if ucsf
  61.     (command "_.UCS" "_P")
  62.   )
  63.   (setvar 'cmdecho cmde)
  64.   (princ)
  65. )
  66.
HTH, M.R.
M.R. on Youtube
andy_lee
« Reply #3 on: July 28, 2015, 11:43:47 AM »
HTH, M.R.
Hi marko
Thank you very much!
Some feedback
  • Need "Pick or specify top center point to place Trapezoid" twice .
  • Can' rotate
andy.
Best regards.
ribarm
« Reply #4 on: July 28, 2015, 02:27:31 PM »
OK, try this mod...
  1. (defun c:Test ( / *error* dtr ac ab p sl a b c d e p ucsf cmde )
  5.   (defun *error* ( msg )
  6.     (if cmde (setvar 'cmdecho cmde))
  7.     (if (not (eq (getvar 'worlducs) 1)) (command "_.UCS" "_P"))
  8.     (if ucsf (command "_.UCS" "_P"))
  9.     (if msg (prompt msg))
  10.     (princ)
  11.   )
  12.   (defun dtr (a) (* pi (/ a 180.0)))
  13.   (if (not *traplen*)
  14.     (setq *traplen* 10.0)
  15.   )
  16.   (if (not *traphgt*)
  17.     (setq *traphgt* 4.0)
  18.   )
  19.   (if (not (eq (getvar 'worlducs) 1))
  20.     (progn
  21.       (command "_.UCS" "_W")
  22.       (setq ucsf t)
  23.     )
  24.   )
  25.   (if (and (setq *traplen* (cond ((getdist (strcat "\n Specify Length of Trapezoid < " (rtos *traplen* 2 2) " > :")))
  26.                                  (*traplen*)
  27.                            )
  28.            )
  29.            (setq *traphgt* (cond ((getdist (strcat "\n Specify Height of Trapezoid < " (rtos *traphgt* 2 2) " > :")))
  30.                                  (*traphgt*)
  31.                            )
  32.            )
  33.            (setq ac (/ *traphgt* (sin (dtr 55.)))
  34.                  ab (* ac (cos (dtr 55.)))
  35.            )
  36.            (if (>= (setq sl (- *traplen* (+ ab ab))) 0.)
  37.              (setq p '(0.0 0.0 0.0))
  38.              (progn (alert "Length of Trapezoid is too small !!") nil)
  39.            )
  40.       )
  41.     (progn (setq a (polar p pi (/ sl 2.))
  42.                  b (polar a (dtr 235.) ac)
  43.                  c (polar b 0. *traplen*)
  44.                  d (polar c (dtr 125.) ac)
  45.                  e (entmakex
  46.                      (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(90 . 4) '(70 . 1))
  47.                              (mapcar '(lambda (pt) (cons 10 (list (car pt) (cadr pt)))) (list a b c d))
  48.                      )
  49.                    )
  50.            )
  51.     )
  52.   )
  53.   (setq cmde (getvar 'cmdecho))
  54.   (setvar 'cmdecho 1)
  55.   (if e
  56.     (progn
  57.       (command "_.copybase" "_non" p e "" "")
  58.       (entdel e)
  59.       (prompt "\nPick face of 3D solid (edge which is parallel to Trapezoid top edge), then adjust UCS further more (Xflip, Yflip, next face if wrong picked) and then press ENTER to accept...")
  60.       (command "_.UCS" "_F")
  61.       (while (< 0 (getvar 'cmdactive)) (command "\\"))
  62.       (setq p (getpoint "\nPick or specify top center point to place Trapezoid : "))
  63.       (command "_.pasteclip" "_non" p)
  64.       (command "_.rotate" (entlast) "" "_non" p "\\")
  65.     )
  66.   )
  67.   (command "_.UCS" "_P")
  68.   (*error* nil)
  69. )
  70.
M.R.
« Last Edit: July 28, 2015, 02:44:41 PM by ribarm »
M.R. on Youtube
andy_lee
« Reply #5 on: July 29, 2015, 12:00:32 AM »
OK, try this mod...
M.R.
marko
You are great . Your help was greatly appreciated.
andy.
Best regards.
