Author Topic: Help with a lisp: PASTEORIG in a new document  (Read 1958 times)
PM
« on: February 28, 2020, 03:40:25 AM »
Hi i need help with a lisp code. I want to select everything (only the oplen layers not the close or frozen) from one drawing and paste them with original coordinates in a new document from specific location. I try this code but when open the new document return to the previous and don't  paste the selected part
  1. (defun c:test ()
  2. (ssget "_x" '((410 . "Model")))
  3. (command "copyclip" (ssget "_x" '((410 . "Model"))))
  4. (setq acDocs (vla-get-documents acApp))
  5. (vla-open acDocs "c:\\myfile\\test\\test.dwg")
  6. (command "PASTEORIG" "")
  7. )
  8.
Tutulisper
  • Mosquito
Re: Help with a lisp: PASTEORIG in a new document
« Reply #1 on: February 28, 2020, 03:50:33 AM »
Hi,you can use "copyobjects " to the new document
this is the code maybe  it useful.
  1.
  2. (defun c:tes(/ app docs doc objects ss i n sslist)
  3.   (setq docs (vla-get-documents app))
  4.   (setq ss (ssget  (list (cons 410  (Getvar"CTAB" )))))
  5.   (setq n (sslength ss)
  6.         i 0)
  7.   (repeat n
  8.     (setq sslist (append sslist (list (vlax-ename->vla-object (ssname ss i)))))
  9.     (setq i (1+ i))
  10.   )
  11.   (setq objects (vlax-make-safearray vlax-vbObject (cons 0  (1- n))))
  12.   (vlax-safearray-fill objects sslist)
  13.   (setq doc_new (vla-add docs "acad.dwt"))
  14.   (vla-copyobjects doc objects (vla-get-modelspace doc_new))
  15.   (vla-saveas doc_new "e:\\drawing.dwg")
  16.   (vla-close doc_new)
  17.   (princ)
  18. )
  19.
  20.
« Last Edit: February 28, 2020, 04:22:02 AM by Tutulisper »
PM
« Reply #2 on: February 28, 2020, 07:53:27 AM »
I have the same layers  in the drawing and the same layers in the dwt but i use different colors in the drawing than in the dwt. When i run the code i miss the colors in the dwt. I want the insert drwing to take the colors from the dwt. Any option ?
PM
« Reply #3 on: February 28, 2020, 01:18:46 PM »
the first way if better to me ,but i have probleme with the paste in original coordinates.Any option?
  1. (defun c:test ()
  7. )
  8.
  9.
PM
« Reply #4 on: February 28, 2020, 04:25:57 PM »
Ok i test again Tutulisper and works perfect. I want to add a layon command and a zoom extend command but is not working because when open the new document paste the drawing ,and return to the first drawing and do the lay on and zoom extend in the first drawing. Can any pne help ?
  1.
  3.       (setq app (vlax-get-acad-object))
  4.       (setq doc (vla-get-activedocument app))
  5.       (setq docs (vla-get-documents app))
  6.       (setq ss (ssget  (list (cons 410  (Getvar"CTAB" )))))
  7.       (setq n (sslength ss)
  8.             i 0)
  9.       (repeat n
  10.         (setq sslist (append sslist (list (vlax-ename->vla-object (ssname ss i)))))
  11.         (setq i (1+ i))
  12.       )
  13.       (setq objects (vlax-make-safearray vlax-vbObject (cons 0  (1- n))))
  14.       (vlax-safearray-fill objects sslist)
  15.       (setq doc_new (vla-add docs "acad.dwt"))
  16.       (vla-copyobjects doc objects (vla-get-modelspace doc_new))
  17.       (vla-saveas doc_new "e:\\drawing.dwg")
  18.       (vla-close doc_new)
  19.       (princ)
  20.     )
  21.
  22.
Tutulisper
  • Mosquito
« Reply #5 on: February 28, 2020, 09:17:57 PM »
I think lisp can not accitve the new document, so zoom the document have no idea ,the lisp reactor maybe can do it but i can not use it.
this code is only copy the objects to the new document.
you can modify the "lock" "freeze"  state。
  1. (defun c:tes (/ app docs doc objects ss i n sslist objlay  insyslay  insyslayobj)
  2.       (setq app (vlax-get-acad-object))
  3.       (setq doc (vla-get-activedocument app))
  4.       (setq docs (vla-get-documents app))
  5.       (setq modelspaceobjs  (vla-get-ModelSpace doc))
  6.       (setq docs (vla-get-documents app))
  7.       (vlax-for obj  modelspaceobjs
  8.         (setq objlay (Vla-Get-Layer obj))
  9.         (setq insyslay (tblobjname "layer" objlay))
  10.         (setq insyslayobj (Vlax-Ename->Vla-Object insyslay))
  11.         ; if the layer is  on then add to the list
  12.         (if (and(= -1 (vlax-get insyslayobj 'layeron));layer is on
  13.                 (= 0 (vlax-get insyslayobj 'lock))    ;layer is not lock
  14.                 (= 0 (vlax-get insyslayobj 'freeze))  ;;layer is not freeze
  15.               )
  16.         (progn
  17.           (setq sslist (append sslist (list obj)))
  18.           )
  19.         )
  20.       )
  21.       (if (> (length sslist) 1 )
  22.         (progn
  23.       (setq objects (vlax-make-safearray vlax-vbObject (cons 0 (1- (length sslist)))))
  24.       (vlax-safearray-fill objects sslist)
  25.       (setq doc_new (vla-add docs "acad.dwt"))
  26.       (vla-copyobjects doc objects (vla-get-modelspace doc_new))
  27.       (vla-saveas doc_new "e:\\drawing.dwg")
  28.       (vla-close doc_new)
  29.         )
  30.       )
  31.       (princ)
  32.   )
  33.
« Last Edit: February 28, 2020, 09:58:22 PM by Tutulisper »
PM
« Reply #6 on: February 29, 2020, 08:50:26 AM »
Hi Tutulisper.I try yourr code but my layer ar stay off. Is any other way to do zoom extend and layon the new document ?
Tutulisper
  • Mosquito
« Reply #7 on: February 29, 2020, 09:41:44 AM »
can use scr to do it
  1. (command "._script" scrfilename)
  2.
  3. in the scrfile like this code
  4. open "e:\drawing.dwg"
  5. ZOOM E qsave close
  6.
  7.
PM
« Reply #8 on: February 29, 2020, 11:54:23 AM »
When the copy the object in the new document return to the previus file. Is any way to go back in the new document and zoom extend and lay on?
Tutulisper
  • Mosquito
« Reply #9 on: February 29, 2020, 08:47:39 PM »
Use lisp  do it is difficult i  have no idea.
you can use vba or c# very easy.
PM
« Reply #10 on: March 02, 2020, 02:39:37 PM »
Thanks for your time.I am not using script files ot vba. I will search more from a solution through lisp.
