Aaaagghhhh, ... help
THEY (the bad guys) changed the server over the weekend.
We have just spent the last four hours trying to fix the mess THEY made for us.
I am in a bit of a pinch and need your help.
I'm not good enough with code to write one quickly that will do what I need.
Can you guys put together a code that will:
Search the drawing for xrefs &/or image files
Drawings have xrefs & image logo's - some are nested
If nested, ALERT user of such, nothing more for nested stuff.
check the path of these xrefs &/or image files
Original path = D:\Drawings ... (Drawings 2005, 2006, or 2007)\ ...
(The path change was only the drive. It changed from D: to X: Everything else in the path is the same)
If the path is D:\Drawings ...
Then change path to X:\Drawings ...
The image logo's are all in the same directory. The only thing that changed was the drive letter, from D:\ ... to X:\ ...
Uuummm, ... what other info do you need ??
ACAD 2007
