Code Red => .NET => Topic started by: It's Alive! on May 04, 2011, 09:34:14 AM
using System;
using System.Diagnostics;
using System.Drawing;
using System.Drawing.Imaging;
using System.Windows.Forms;
using Teigha.Runtime;
using Teigha.DatabaseServices;
using Teigha.Geometry;
using BricscadDb;
using BricscadApp;
using Bricscad.ApplicationServices;
using Bricscad.Runtime;
using Bricscad.EditorInput;
using AcAp = Bricscad.ApplicationServices;
using AcDb = Teigha.DatabaseServices;
using AcGe = Teigha.Geometry;
using AcEd = Bricscad.EditorInput;
[assembly: CommandClass(typeof(CsDanTheMan.Commands))]
namespace CsDanTheMan
public class Commands
//http://pietschsoft.com/post/2008/07/c-generate-webpage-thumbmail-screenshot-image.aspx
public Bitmap GenerateScreenshot(string url)
return GenerateScreenshot(url, -1, -1);
public Bitmap GenerateScreenshot(string url, int width, int height)
WebBrowser wb = new WebBrowser();
wb.ScrollBarsEnabled = false;
wb.ScriptErrorsSuppressed = true;
wb.Navigate(url);
while (wb.ReadyState != WebBrowserReadyState.Complete)
System.Windows.Forms.Application.DoEvents();
wb.Width = width;
wb.Height = height;
if (width == -1)
wb.Width = wb.Document.Body.ScrollRectangle.Width;
if (height == -1)
wb.Height = wb.Document.Body.ScrollRectangle.Height;
Bitmap bitmap = new Bitmap(wb.Width, wb.Height);
wb.DrawToBitmap(bitmap, new Rectangle(0, 0, wb.Width, wb.Height));
wb.Dispose();
return bitmap;
[CommandMethod("SWAMPTOCAD")]
public void SWAMPTOCAD()
Bitmap bitmap = GenerateScreenshot("http://www.theswamp.org/index.php");
bitmap.RotateFlip(RotateFlipType.RotateNoneFlipY);
Database db = AcAp.Application.DocumentManager.MdiActiveDocument.Database;
AcDb.BlockTableRecord currentSpace = tr.GetObject
(db.CurrentSpaceId, OpenMode.ForWrite) as AcDb.BlockTableRecord;
for (int i = 0; i < bitmap.Width; i++)
for (int j = 0; j < bitmap.Height; j++)
DBPoint point = new DBPoint(new Point3d(i, j, 0.0));
point.Color = Teigha.Colors.Color.FromColor(bitmap.GetPixel(i, j));
currentSpace.AppendEntity(point);
tr.AddNewlyCreatedDBObject(point, true);
tr.Commit();
:-D
