Author Topic: Reload without "vla"  (Read 2346 times)
whdjr
« on: October 05, 2004, 09:12:14 AM »
Is there a way to relaod an xref without using the vla commands?
  • Custom Title
« Reply #1 on: October 05, 2004, 09:14:23 AM »
How about this.
(command "_xref" "r" "name-of-xref")
whdjr
« Reply #2 on: October 05, 2004, 09:18:03 AM »
duh.....too easy!
Thanks, Mark
CADaver
« Reply #3 on: October 05, 2004, 12:30:56 PM »
(DEFUN C:xru ()
(command "-xref" "unload" (cdr (assoc 2 (ENTGET (CAR (ENTSEL "\N Select Element in XREF to UNLOAD  "))))))
(DEFUN C:xrd ()
(command "-xref" "detach" (cdr (assoc 2 (ENTGET (CAR (ENTSEL "\N Select Element in XREF to DETACH  "))))))
(DEFUN C:xre ()
(command "-xref" "reload" (cdr (assoc 2 (ENTGET (CAR (ENTSEL "\N Select Element in XREF to RELOAD  "))))))
(DEFUN C:xrua () (command "-xref" "unload" "*"))
(DEFUN C:xrea () (command "-xref" "reload" "*"))
(DEFUN C:xrda () (command "-xref" "detach" "*"))
