Author Topic: CDG Purge 4.0 problem  (Read 1482 times)
Notsober
« on: September 04, 2008, 05:03:48 PM »
hello again!
remember my 42MB dwg problem? it's back. only this time, i have dwgs that are getting BIGGER when I use CDG Purge!
I tried all my past "fixes" and they are not working...
I do a simple purge, and the dwgs go from say, 105kb to 250kb! when I use CDG Purge, dwgs go from 250kb to 1.8MB!!
What's the deal?
David Hall
  • Automatic Duh Generator
Re: CDG Purge 4.0 problem
« Reply #1 on: September 04, 2008, 05:21:06 PM »
can you post the file for us to look at?
Notsober
« Reply #2 on: September 04, 2008, 05:35:51 PM »
i had to delete all the confidential stuff, and lo and behold... the dwg went from 130kb to 1.8MB!
but here it is.
« Reply #3 on: September 04, 2008, 06:35:12 PM »
see if this one is better.
*saved to 2004
« Last Edit: September 05, 2008, 10:56:01 AM by ronjonp »
Notsober
« Reply #4 on: September 05, 2008, 07:53:00 AM »
I get an error: Dwg is not valid
did you resave it down as 2004 or 2000?
I suppose I forgot to mention that I'm working with A2004.
[edit: don't worry, I converted it myself using DWG TrueConvert]
« Last Edit: September 05, 2008, 08:17:05 AM by Robert Holland »
Notsober
« Reply #5 on: September 05, 2008, 08:38:34 AM »
so what did you do, other than open it and save it using a newer ACAD?
cuz I still need to *fix* the original dwg.
« Reply #6 on: September 05, 2008, 11:06:36 AM »
Run Michael's "counts" routine to see what's in the drawing. I'm not sure why the drawing is so big :?
http://www.theswamp.org/index.php?topic=9433.0
Notsober
« Reply #7 on: September 05, 2008, 02:23:50 PM »
this was ran in the original dwg BEFORE CDG Purge was run...
I don't notice anything unusual.... what I'm wondering is why does the dwg jump from 331kb to 1.8MB after I run CDG Purge??
Command: counts
Blocks.Count = 79
    *MODEL_SPACE.Count = 5931
    *PAPER_SPACE.Count = 0
    CHEVLOGO.Count = 70
    FSHT.Count = 100
    MISC5.Count = 2
    A$C3391.Count = 11
    ISO260.Count = 6
    ISO246.Count = 3
    iso144.Count = 1
    ISOARROW.Count = 1
    MISC5A.Count = 2
    ISO143.Count = 1
    iso230.Count = 5
    iso231.Count = 5
    iso226x.Count = 5
    iso228x.Count = 5
    112-90lre.Count = 5
    *U15.Count = 11
    *U16.Count = 11
    *U17.Count = 11
    *U18.Count = 11
    *U19.Count = 11
    *U20.Count = 11
    *U21.Count = 11
    *U22.Count = 11
    *U23.Count = 11
    *U24.Count = 11
    *U25.Count = 11
    *U26.Count = 11
    *U27.Count = 11
    *U28.Count = 11
    *U29.Count = 11
    *U30.Count = 11
    *U31.Count = 11
    *U32.Count = 11
    *U33.Count = 11
    *U34.Count = 11
    *U35.Count = 11
    *U36.Count = 11
    *U37.Count = 11
    *U38.Count = 11
    *U39.Count = 11
    *U40.Count = 11
    *U41.Count = 11
    *U42.Count = 11
    *U43.Count = 11
    *U44.Count = 11
    *U45.Count = 11
    *U46.Count = 11
    *U47.Count = 11
    *U48.Count = 11
    *U49.Count = 11
    *U50.Count = 11
    *U51.Count = 11
    *U52.Count = 11
    *U53.Count = 11
    *U54.Count = 11
    *U55.Count = 11
    *U56.Count = 11
    *U57.Count = 11
    *U58.Count = 11
    *U59.Count = 11
    *U60.Count = 11
    *U61.Count = 11
    *U62.Count = 11
    *U63.Count = 11
    *U64.Count = 11
    *U65.Count = 11
    *U66.Count = 11
    *U67.Count = 11
    *U68.Count = 11
    *U69.Count = 11
    *U70.Count = 11
    *U71.Count = 11
    *U72.Count = 11
    iso275.Count = 18
    ISO450.Count = 5
    iso225.Count = 5
    iso224.Count = 5
Dictionaries.Count = 10
    ACAD_COLOR.Count = 0
    Groups.Count = 0
    ACAD_IMAGE_DICT.Count = 1
    Layouts.Count = 2
    ACAD_MATERIAL.Count = 3
    ACAD_MLINESTYLE.Count = 1
    PlotConfigurations.Count = 1
    ACAD_PLOTSTYLENAME.Count = 1
    AcadDim has no <Count> property.
    ACDBVARIABLEDICTIONARY.Count = 3
DimStyles.Count = 1
Groups.Count = 0
Layers.Count = 18
Layouts.Count = 2
Linetypes.Count = 8
RegisteredApplications.Count = 17
Modelspace.Count = 5931
Paperspace.Count = 0
Crank
« Reply #8 on: September 09, 2008, 01:08:23 PM »
There are almost 5000 empty texts in this drawing. Do erase all remove crossing (now select everything visible) to get rid of them.
