Code Red => AutoLISP (Vanilla / Visual) => Topic started by: HasanCAD on October 14, 2010, 02:03:29 PM
How ro add a layer description
DXF code is 1000 Xdata I tried to add as
(defun Layer (Nme)
(entmake (list (cons 0 "LAYER")
(cons 100 "AcDbSymbolTableRecord")
(cons 100 "AcDbLayerTableRecord")
(cons 2 Nme)
(cons 1000 "123")
(cons 70 0))))
follows but gives an error
Command: (layer nme)
; error: too few arguments
http://www.theswamp.org/index.php?topic=33041.0
Thanks CAB
You're quite welcome.
Thanks CAB
Notice: CreateLayer from VovKa doesn't work in AutoCAD 2011.
The problem is the line:
(list -3 (list "AcAecLayerStandard" (cons 1000 "") (cons 1000 Desc)))
Regards
perhaps you must use
(regapp "AcAecLayerStandard")
before...
e.fernal
Thanks, with (regapp "AcAecLayerStandard") the program CreateLayer
http://www.theswamp.org/index.php?topic=35302.0 using entmake works.
You are posting a link to the same thread
and E. Fernal answered: Perhaps you must use
(regapp "AcAecLayerStandard") before...
And my conclusion is: it works.
Regards.
