Author Topic: Probem with WblockCloning PropertySets  (Read 2390 times)
mgreven
« on: August 22, 2012, 04:02:24 PM »
Hello,
I have made a routine to WblockClone PropertySets between drawings...
When i use the routine i am getting a "Exception: eInvalidInput" on the commandline and the PropertySet is Not Cloned to the drawing.
What is wrong here?
        Sub WblockPropsets(ByVal SourceDrawing As String, ByVal PropsetName As String)
            ' Connect to Current Drawing
            Dim MyDWG As Autodesk.AutoCAD.ApplicationServices.Document = _ Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim MyDB As Autodesk.AutoCAD.DatabaseServices.Database = MyDWG.Database
            Dim MyTransMan As Autodesk.AutoCAD.DatabaseServices.TransactionManager = MyDWG.TransactionManager
            ' Connect to Source Drawing
            Using SrcDB As Autodesk.AutoCAD.DatabaseServices.Database = New Autodesk.AutoCAD.DatabaseServices.Database(False, True)
                ' Read Source Drawing
                SrcDB.ReadDwgFile(SourceDrawing, IO.FileShare.ReadWrite, True, "")
                ' Start Transactions
                Dim SrcTransMan As Autodesk.AutoCAD.DatabaseServices.TransactionManager = SrcDB.TransactionManager
                Using SrcTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = SrcTransMan.StartTransaction,
                        MyTrans As Autodesk.AutoCAD.DatabaseServices.Transaction = MyTransMan.StartTransaction
                    ' Open de source PropSet Dictionary...
                    Dim SrcPropsetDict As New DictionaryPropertySetDefinitions(SrcDB)
                    ' Open de destination PropSet Dictionary and get de Dictionary ID...
                    Dim DestPropsetDict As New DictionaryPropertySetDefinitions(MyDB)
                    Dim DestPropsetDictID = DestPropsetDict.DictionaryId
                    Dim MyPropSetColl As New Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection ' Colection that Stores the Entities ID
                    ' Get the collection of MvBlocks...
                    ' Loop entities in Source Dictionary
                    For Each ObjID In SrcPropsetDict.Records
                        Dim PropSet As PropertySetDefinition = SrcTrans.GetObject(ObjID, OpenMode.ForRead)
                        If PropSet.Name = PropsetName Then
                            MyPropSetColl.Add(ObjID)
                        End If
                    Next
                    ' WblockClone the Source Entitys
                    Dim myMap As New Autodesk.AutoCAD.DatabaseServices.IdMapping
                    MyDB.WblockCloneObjects(MyPropSetColl, DestPropsetDictID, myMap, Autodesk.AutoCAD.DatabaseServices.DuplicateRecordCloning.Replace, False)
                    ' Commit, Close and Dispose Transactions
                    MyTrans.Commit()
                    SrcTrans.Commit()
                End Using
            End Using
        End Sub
kaefer
Re: Probem with WblockCloning PropertySets
« Reply #1 on: August 23, 2012, 12:47:18 AM »
What is wrong here?
You could try Autodesk.Aec.ApplicationServices.Utility.CloningHelper() instead. This was described recently on Autodesk's AEC DevBlog.
mgreven
« Reply #2 on: August 24, 2012, 06:20:16 PM »
Thanks for your help... It does the trick.
Regards,
Marco
