Author Topic: Getting ss from last copy command  (Read 4480 times)
Amsterdammed
« on: April 04, 2007, 08:18:01 PM »
Hello everybody,
I wonder if there is a way to get all new entities made by a copy command, like i do with a single entity:
(command "copy" en "" pt ptn)
(setq en1 (entlast))
How can I get ss1 when i copy ss?
Thanks in Advance
Bernd
Crank
Re: Getting ss from last copy command
« Reply #1 on: April 04, 2007, 09:02:55 PM »
If you look for the last entity in the database before the copy command, you can find all new created entities with entnext.
(setq last1 (entlast))
(command "._copy" en "" pt ptn)
(setq ss1 (collect last1))
(defun collect (el / ex ss)
(setq ex (entnext el)
        ss (ssadd ex (ssadd)))
(setq ex (entnext ex))
(while ex
(setq ss (ssadd ex ss) ex (entnext ex))
ss
« Last Edit: April 04, 2007, 09:24:23 PM by Crank »
« Reply #3 on: April 04, 2007, 09:13:47 PM »
or traditionally ..
;; // MarkCatch.LSP
;; based on New Rider Articles { I think }
;;;  KB:mark
;;;* Mark data base to allow KB:catch.
(DEFUN kb:mark (/ val)
   (SETQ val (GETVAR "cmdecho"))
   (SETVAR "cmdecho" 0)
   (IF (SETQ *KG:mark (ENTLAST))
      nil
      (PROGN (ENTMAKE '((0 . "POINT") (10 0.0 0.0 0.0)))
             (ENTDEL *KG:mark)
   (SETVAR "cmdecho" val)
   (PRINC)
;;;  KB:catch
;;;* returns selection set of entities since last KB:mark.
(DEFUN kb:catch (/ ss tmp)
   (IF *KG:mark
      (PROGN (SETQ ss (SSADD))
             (WHILE (SETQ *KG:mark (ENTNEXT *KG:mark)) (SSADD *KG:mark ss))
             (COMMAND "._select" ss "")
             (SETQ tmp ss)
      (ALERT "*KG:mark not set. \n Run KB:mark before KB:catch.")
(DEFUN C:testit ()
   (kb:mark)
   (PROMPT "\n  Select stuff to Copy ")
   (SETQ ss (SSGET))
   (INITGET 32)
   (COMMAND "_copy" ss "" "\\" "\\")
   (SETQ ss1 (kb:catch))
« Reply #4 on: April 04, 2007, 09:15:36 PM »
The method outlined above will allow the collection across multiple commands including exploding blocks etc ...
Amsterdammed
« Reply #5 on: April 05, 2007, 07:54:47 AM »
Thanks Kerry,
that is great. That exploding block thing is indeed something Very usefull and more than I asked for :lol:
Thanks again, everybody
Bernd
Amsterdammed
« Reply #6 on: April 05, 2007, 07:59:49 AM »
Crank,
thanks, your solution is doing the same, but you with the last entry at the moment of the copy instead of a benchmark. works great, too, with less code. :-)
Bernd
Patrick_35
« Reply #7 on: April 05, 2007, 12:01:19 PM »
You can use a reactor
;;; JSD.LSP V2.00
;;; Jeu de Sélection de ce qui a été créé
;;; Copyright (C) Patrick_35
(defun commencer_jeu__selection(Rea Cde)
  (if (member (car Cde) '("COPY" "MIRROR" "GRIP_MIRROR" "ARRAY"))
    (setq $ (ssadd))
(defun ajouter_jeu_de_selection (Rea Obj)
  (if (not (eq (cdr (assoc 0 (entget (cadr Obj)))) "ATTRIB"))
    (ssadd (cadr Obj) $)
(defun enlever_jeu_de_selection (Rea Obj)
  (ssdel (cadr Obj) $)
(defun faire_jeu_de_selection()
  (setq mrea_jsd (vlr-command-reactor nil (list (cons :vlr-commandWillStart (function commencer_jeu__selection))
mrea_fin (vlr-acdb-reactor    nil (list (cons :vlr-objectAppended   (function ajouter_jeu_de_selection))
(cons :vlr-objectUnErased   (function ajouter_jeu_de_selection))
(cons :vlr-objectErased     (function enlever_jeu_de_selection))
  (princ "\nSelection of what is created ready, use !$ at the command line.")
(if (not mrea_jsd)
  (faire_jeu_de_selection)
But I have a problem.  :-(
When I do for example a copy of objects of which there are blocks with attributes, a (sslength $) gives me well what was copied.
I make a undo and it's always good.
Now, if I do a MREDO, I have the surprise to discover that the result of (sslength $) corresponds to the number of objects which had been copied more the number of attributes.  :-o
I seek in vain from where the error can come and I do not find  :?
« Reply #8 on: April 05, 2007, 09:37:20 PM »
Why would anyone want to add a command reactor for something like this .. just MORE bottleneck potential ..
Patrick_35
« Reply #9 on: April 06, 2007, 02:08:30 AM »
Because you can use it at the command line. for example, If you want to select a past from an another drawing, it's more easy whith this.
You have an additional option of selection at the command line.
« Reply #10 on: April 06, 2007, 06:53:46 AM »
I like the idea but I'm with Kerry on the potential time penalty you may have to pay.
My system is feeling too slow as it is.
Still wishing for a new computer, ah maybe my Birthday.  :oops:
