In micro station V8i there is an option to array objects as per a polyline's path. However autocad has only rectangular/polar options.
Currently i am using offset-divide-copy-paste method. Is there a quickerway or does someone have a program that does this?
Am using AutoCAD 2007
Cheers.
The bad news is that 2012 supports this type of array (now). However I won't tell you to upgrade.
With the Divide and Measure commands one can place a block, effectively creating an ARRAY.
I'm trying to remember if 2007 supports Dynamic Blocks; if it does an alignment parameter can aide in keeping the blocks aligned correctly to the path.
The difference is in 2012 the arrayed objects are dynamically linked to the path object.
I think there might be a routine somewhere here at the swamp that also creates a dynamic aray.
http://www.theswamp.org/index.php?topic=39015.msg448981#msg448981
