Author Topic: Invisible viewport  (Read 13993 times)
Re: Invisible viewport
« Reply #45 on: January 09, 2015, 04:18:19 PM »
DEFPOINTS layer is ONLY for autocad to keep track of Dimension Origins
Objects on it will revert to plotable objects after you run AUDIT command anyway
They get 'locked' if layer zero (0) is turned off or locked...or similar symptoms
So, just quit it, OK?
I was aware of why Defpoints is there.
I have run AUDIT and not had that problem...ever.
Locked as in need to hit unlock to manage them again? Or as in no longer changable at all?
I'm thinking about it!  :straight: I tend to have issues with viewports on a VP layer and not when they are on defpoints...?? No specific example of this though.  :|
#LORAX VOICE#
You have been WARNED!
#LORAX VOICE#
Bethrine
« Reply #46 on: January 09, 2015, 04:27:12 PM »
#LORAX VOICE#
#LORAX VOICE#
 :wideeyed: Now I'm jinxed. Thanks. Okay, I'll stop. Ugh. This will be interesting.
« Reply #47 on: January 09, 2015, 04:30:42 PM »
Cathy
« Reply #48 on: January 09, 2015, 05:15:29 PM »
The viewport is CLIPPED.  I think if you just do a MVIEW Restore, it will UNCLIP it and you can see it again.
« Reply #49 on: January 09, 2015, 06:02:17 PM »
Some people take their DEFPOINTS layer way too seriously. :)
Rob...
« Reply #50 on: January 09, 2015, 06:07:59 PM »
It's not theirs, its AutoCAD's.
CAD Tech
« Reply #51 on: January 09, 2015, 06:23:43 PM »
When it is in MY drawing it's my layer & I'll do with it what I want.  :P
Scott
« Reply #52 on: January 09, 2015, 11:22:35 PM »
tedg
« Reply #53 on: January 12, 2015, 09:21:59 AM »
This is a very hot topic in AUGI as well, lots of good reasons not to use defpoints, mostly because since 2000, we've been given the ability to create non-plotting layers, so why risk it.
Just a few discussions on the issue:
http://forums.augi.com/showthread.php?155846-Defpoints-and-Layer-0&p=1266702&viewfull=1#post1266702
http://forums.augi.com/showthread.php?120475-Can-not-select-viewportsr
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
Bethrine
« Reply #54 on: January 12, 2015, 09:42:04 AM »
THAT was very informative and helpful! I will certianly be creating a no plot layer for things I don't want to plot from now on! From reading those, I bet this solves a couple of problems I've had on and off.  :idea:
Should I move the one's I've alredy put on defpoints off of there?  :sick:
cadtag
« Reply #55 on: January 12, 2015, 09:51:02 AM »
If you think there's any chance at all those dwg files will every be opened again in the next 30 years, then yes.
tedg
« Reply #56 on: January 12, 2015, 09:55:03 AM »
I bet some clever lisper could write some code that automatically places viewports on a pre-defined no plot layer upon opening your drawings... maybe within an acaddoc.lsp.
Just a thought.
But yes, I would move your viewport(s) to a layer that isn't defpoints (if I were you).
« Reply #57 on: January 12, 2015, 09:56:13 AM »
That's good info. I never use it myself but do receive drawing with view ports on that layer.
I guess I'll start cleaning them up before sending back to the originator.
Bethrine
« Reply #58 on: January 12, 2015, 10:21:11 AM »
Two thoughts:
1) I bet Zero and Defpoints being connected have something to do with block creation.
2) I wonder if this has been part of the cause of problems I've had moving stuff between AutoCAD and Inventor? (Something I get better at every time I need to do it.)
« Reply #59 on: January 12, 2015, 10:24:49 AM »
Two thoughts:
NOT Exactly
