Code Red => AutoLISP (Vanilla / Visual) => Topic started by: One Shot on April 28, 2005, 03:44:07 PM
I needed to remove the reactor in this lisp. Here is the lisp before I removed it.:
;;; Date Modified: 04/26/05
;;; By Whom: Bcrouse
;; To see the styles in a DWG enter -style at the command line, then ?
;; This changes text & Mtest from one style to another
;; The old style is still in the drawing
(defun c:BCtxtfix ()
(command "_.undo" "begin")
(StyleChange "DWGTITLE" "DWGTITLES")
(StyleChange "HANDDWGTITLE" "DWGTITLES")
(StyleChange "HANDWGTITLE" "DWGTITLES")
(StyleChange "HANDWGTITLES" "DWGTITLES")
(StyleChange "HANSHTITLES" "RMNAMES")
(command "_.-purge"
"textstyles"
"DWGTITLE,HANDDWGTITLE,HANDWGTITLE,HANDWGTITLEs,HANSHTITLES"
"N"
(command "_.regen")
(command "_.undo" "end")
(defun StyleChange (OlSty NuSty / n ss entList NextEnt)
(setq OlSty (strcase OlSty)) ; force upper case
(setq NuSty (strcase NuSty))
;;build a filter to select only text with that style
;;Note: DXF group code 7 is the style of a text entity
;; 0 is the entity type
((null (setq ss (ssget "X"
(list '(0 . "TEXT,MTEXT")
(cons 7 OlSty)
) ;put the text in a selection set.
(alert (strcat "Found No text with style " OlSty))
;;check and make sure NuSty exist
((tblsearch "STYLE" NuSty)
(setq n 0) ;set a counter
;;loop until all ents changed
(while (setq NextEnt (ssname ss n)) ;grab the first ent in the ss
(setq EntList (entget NextEnt)) ;get the list
(setq EntList (subst (cons 7 NuSty)
(assoc 7 EntList)
EntList)) ;replace it in the list
(entmod EntList) ;change the ent
(entupd (cdr (assoc -1 EntList))) ;update the screen
(setq n (1+ n)) ;increment
) ;_ end of while
(alert (strcat (itoa n) " Items Changed "))
(T ;otherwise you blew it.
(alert (strcat "Hey You,\n\n" NuSty " doesn't exist!"))
);_ end of cond
(setvar "cmdecho" 1)
) ;_ end of defun
Here is the modified lisp with the reactors removed. Did I do that correctly. If not, please point me in the right direction.:
;;; Date Modified: 04/27/05
(command "_.-purge"
"textstyles"
"N"
(command "_.regen")
(cons 7 OlSty)
(assoc 7 EntList)
) ;_ end of while
);_ end of cond
) ;_ end of defun
Thank you for all of you help.
Are you referring to the lines that start with;
(alert...)
if so just add a ';' (semi-colon) in front of them and then run the program. Is that what you want?
(alert...)
Mark,
Yes that is correct. Thank you for your help.
Brad
