Author Topic: Help on my Rectangular RevCloud  (Read 6884 times)
Re: Help on my Rectangular RevCloud
« Reply #15 on: September 21, 2012, 11:00:08 PM »
because it was the last statement evaluated in the routine
modify to
  1. ;; < .. remainder not shown ... >
  2.    (setvar 'osmode old_osm)
  3.    (princ)             ;;<<<--- add
  4. )
RolandOrzabal
  • "memories fade but the scars still linger"
« Reply #16 on: September 22, 2012, 12:10:29 AM »
modify to
  4. )
I see! thanks a lot Kerry!
that worked!
« Reply #17 on: September 22, 2012, 12:51:12 AM »
You're welcone noddy.
